查看: 3011|回复: 2
[资料] Hilbert–Huang transform Matlab lib
发表于 2014-3-13 05:23:57 | 显示全部楼层 |阅读模式
The Hilbert–Huang transform (HHT) is a way to decompose a signal into so-called intrinsic mode functions (IMF), and obtain instantaneous frequency data. It is designed to work well for data that is nonstationary and nonlinear. In contrast to other common transforms like the Fourier transform, the HHT is more like an algorithm (an empirical approach) that can be applied to a data set, rather than a theoretical tool.
HHT MATLAB program
Matlab_HHT.zip (194.01 KB , 下载次数: 27 )
Tutorial for the HHT MATLAB program
Tutorial for the HHT MATLAB.pdf (342.05 KB , 下载次数: 29 )
发表于 2018-8-14 19:42:58 | 显示全部楼层
thanks
发表于 2023-3-31 15:37:19 | 显示全部楼层
谢谢
GMT+8, 2025-12-12 19:46 , Processed in 0.020617 second(s), 7 queries , Gzip On, Redis On.
