查看: 8953|回复: 13
[求助] (求助)新加了个库,cadence仿真不通过
发表于 2014-3-9 22:32:10 | 显示全部楼层 |阅读模式
各位大侠,小弟最近给服务器上新放了个库,但是在仿真时没办法通过,是报表是这样的,想请各位帮忙解决!!!
mand line:
        /cad/apps/cadence/cic/5.141.6.150/tools.lnx86/spectre/bin/32bit/spectre  \
        -env artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre1_8898_5 -format sst2 -raw ../psf +lqtimeout  \
        900 input.scs
spectre pid = 10175
Loading /cad/apps/cadence/cic/5.141.6.150/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so
Loading /cad/apps/cadence/cic/5.141.6.150/tools.lnx86/cmi/lib/4.0/libnortel_sh.so
Loading /cad/apps/cadence/cic/5.141.6.150/tools.lnx86/cmi/lib/4.0/libphilips_sh.so
Loading /cad/apps/cadence/cic/5.141.6.150/tools.lnx86/cmi/lib/4.0/libsparam_sh.so
Loading /cad/apps/cadence/cic/5.141.6.150/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so
spectre (ver. 5.10.41.121508 -- 15 Dec 2008).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
        Security, Inc.
Simulating `input.scs' on cflvdc10 at 10:55:26 PM, Sun Mar 9, 2014.
Error found by spectre during circuit read-in.
    "input.scs" 8: Unable to run circuit preprocessor
        (/cad/apps/cadence/cic/5.141.6.150/tools.lnx86/bin/spp).
        Illegal seek.
    "input.scs" 8: Failed to include file
        `/home/wuyw/smic65_pdk/l0065ll_v1p5_spe.lib' and section `tt'.
    "input.scs" 9: Unable to run circuit preprocessor
        Illegal seek.
    "input.scs" 9: Failed to include file
        `/home/wuyw/smic65_pdk/l0065ll_v1p5_spe.lib' and section `bjt_tt'.
    "input.scs" 10: Unable to open input file
        `/home/wuyw/smic65_pdk/l0065ll_v1p5_res_spe.ckt'.
        No such file or directory.
spectre terminated prematurely due to fatal error.
发表于 2014-4-28 11:08:42 | 显示全部楼层
同问~
发表于 2014-4-29 00:14:43 | 显示全部楼层
提示信息不是很明确了么,没有找到.lib文件。你在检查下时间否路径错了
发表于 2014-5-1 08:24:36 | 显示全部楼层
没有找到.lib文件
发表于 2014-5-1 08:59:35 | 显示全部楼层
没有找到.lib文件
发表于 2016-3-15 11:16:20 | 显示全部楼层
回复 3# oxplorer
我也遇到了上面的问题。我想问一下,我检查后路径没有错误,那下面应该怎么办?
发表于 2016-4-20 13:08:51 | 显示全部楼层
回复 1# wuyanwei
楼主您的问题解决了吗?我也遇到了同样的问题。
发表于 2016-7-12 14:57:00 | 显示全部楼层
同问..............
发表于 2016-8-25 18:16:43 | 显示全部楼层
我碰到的情况不知道一样不一样,我发现有问题是自己的设计没有attach到工艺库上,attach到工艺库文件,然后发现与其他的有些文件有缺失,于是我又把/eda/.(此处是我的工艺库文件地址)./smic18mm下面的models,assure..等文件一块拷贝到/我的文件/工艺库下的(我的是放在smic18mm同一个文件夹下的
不知问题是否一样,管不管用
发表于 2016-8-26 08:19:06 | 显示全部楼层
路径没错的话,那就是section的参数错了,去model文件仔细检查一下
GMT+8, 2025-12-30 10:34 , Processed in 0.023087 second(s), 6 queries , Gzip On, Redis On.
