发表于 2007-9-15 15:41:30
显示全部楼层
/*以下是FM.h*/
/* MODULE: */
FM.h
* TCC Version 0.0
* Copyright (c) telechips, Inc.
* ALL RIGHTS RESERVED
//dddxxx
#include "tcc760.h"
#ifdef RADIO_MCU
//#define fm_pwr_off HwGDATA_D &= ~(1 << 19) // Fm power off
//#define fm_pwr_on HwGDATA_D |= (1 << 19) // Fm power on
#define mcu_slaveaddr 0x54
#define COM_RADIO_STATE 0x40
#define COM_RADIO_FREQ 0x41
#define RADIO_SET_STERO 0x10
#define RADIO_SET_PWR 0x20
#define RADIO_SET_SENS_005 0x00
#define RADIO_SET_SENS_010 0x80
#define RADIO_SET_SENS_030 0x40
#define RADIO_SET_SENS_150 0xc0
#define RADIO_AUTOSCAN_UP 0x01
#define RADIO_AUTOSCAN_DOWN 0x02
#define RADIO_MANUSCAN_UP 0x04
#define RADIO_MANUSCAN_DOWN 0x08
#define RADIO_FM 0x00
#define RADIO_AM 0x01
#define RADIODELAY 100
enum{
PRESET_MODE_OFF,
PRESET_MODE_ON,
NO_MODE,
MANUAL_ADD_CH
#define off 0
#define on 1
#define up 1
#define down 0
#define MAX_PRESET_NUM 20
typedef struct BANKOFRADIO {
unsigned char IsPreset ;
unsigned char IsStereo;
unsigned short LastUseFMHz;
unsigned short Presetbank[MAX_PRESET_NUM] ;
unsigned char LastUsePresetNum;
unsigned char LastBand;
} FMRADIO;
extern unsigned int fm_khz;
extern FMRADIO RadioData;
extern void delay720(unsigned int count);
extern void fm_init(void);
extern void fmw_stand_by_rtn(unsigned char onoff);
extern void fmw_stereo_rtn(unsigned char onoff);
extern void mcu_send_state(void);
extern unsigned char mcu_read_radio_state(void);
extern unsigned int mcu_read_radio_freq(void);
extern void Radio_manual_scan(unsigned char dir);
extern void Radio_auto_scan(unsigned char dir);
#else
#define fm_slaveaddr 0xc0 // FM modules slave addr
#define fm_pwr_off HwGDATA_A |= (1 << 13); // Fm power off
#define fm_pwr_on HwGDATA_A &= ~(1 << 13); // Fm power on
enum{
PRESET_MODE_OFF,
PRESET_MODE_ON,
NO_MODE,
MANUAL_ADD_CH
#define off 0
#define on 1
#define up 1
#define down 0
#define all_level 0
#define lo_level 1
#define mid_level 2
#define hi_level 3
#define japan 1 // Japan band
#define us_eu 0 // US/EU band
#define xtal_32768 1 // set the x-tal to 32.768 KHz
#define xtal_13m 0 // set the x-tal to 13 MHz
#define ref_65_en 1 // 6.5 MHz reference for PLL enabled
#define ref_65_dis 0 // 6.5 MHz reference not enabled
#define deemph75 1 // deemphasis time constant is 75 us
#define deemph50 0 // deemphasis time constant is 50 us
#define hi_side 1 // FM module's high-side injcetion
#define lo_side 0 // FM module's low-side injection
// when you do not use the autonomous search mode of the FM module, set the scan level and step
#define scan_level 6 // the available values are 0 ~ 15
#define scan_step 100 // KHz unit
extern void LCD_DisplayChannelForFM(int InputHz);
extern unsigned char fm_wr_rtn(unsigned char *ptr);
// Struct for Radio data
} FMRADIO;
extern unsigned char fm_wr_byte[5];
extern unsigned char fm_hilo_optimal(unsigned int fm_freq);
extern void fmw_pll_rtn(unsigned char hilo, unsigned int fm_freq);
extern void fmw_all_mute_rtn(unsigned char onoff);
extern unsigned int fm_auto_scan_detect(unsigned char dir);
extern unsigned char fm_auto_scan(unsigned char dir);
extern void fm_manual_scan(unsigned char dir);
#endif
/* MODULE: */
/* FM.c
* TCC Version 0.0
#include "main.h"
#include "fm/FM.h"
#include "kernel/telechips.h"
#include "i2c/i2c.h"
FMRADIO RadioData;
#ifdef RADIO_INCLUDE
#ifdef RADIO_MCU
unsigned char radio_state = RADIO_SET_STERO|RADIO_SET_SENS_150;
unsigned int radio_freq ;
unsigned char command_buff[2];
unsigned char receive_data[2];
unsigned char radio_pwron_counter=0;
for(;count>0;count--) ;
// 1:0.84, 5:1.36, 10:1.96, 20:3.20, 30:4.48, 60:8.04, 80:10.6, 90:11.6, 100:13
void fmw_stand_by_rtn(unsigned char onoff) //radio power onoff
// if(onoff)
// fm_pwr_on;
// else
// fm_pwr_off;
if(onoff)
radio_state &= ~RADIO_SET_PWR;
radio_pwron_counter=1;
else radio_state |= RADIO_SET_PWR;
mcu_send_state();
//radio_state &= 0xcf;
//if(onoff)
// radio_state |= RADIO_SET_STERO;
//else radio_state |= RADIO_SET_MONO;
if(onoff)
else radio_state &= ~RADIO_SET_STERO;
mcu_send_state();
unsigned char mcu_rd_rtn(unsigned char subadr,unsigned char *ptr, unsigned char bytes)
return (unsigned char)(i2c_read((unsigned int)I2C_FM, (unsigned char)mcu_slaveaddr, subadr, ptr, bytes));
unsigned char mcu_wr_rtn(unsigned char subadr,unsigned char *ptr, unsigned char bytes)
return (unsigned char)(i2c_write((unsigned int)I2C_FM, (unsigned char)mcu_slaveaddr, subadr, ptr, bytes));
void mcu_set_state(unsigned char *com)
mcu_wr_rtn(COM_RADIO_STATE,com,1);
void mcu_set_freq(unsigned char *com)
mcu_wr_rtn(COM_RADIO_FREQ,com,2);
void mcu_read_state(unsigned char *com)
mcu_rd_rtn(COM_RADIO_STATE,com,1);
void mcu_read_freq(unsigned char *com)
mcu_rd_rtn(COM_RADIO_FREQ,com,2);
command_buff[0] = radio_state;
mcu_set_state(command_buff);
void mcu_manuscan_up(void)
radio_state &= 0xf0;
radio_state |= RADIO_MANUSCAN_UP;
mcu_send_state();
void mcu_manuscan_down(void)
radio_state |= RADIO_MANUSCAN_DOWN;
mcu_send_state();
void mcu_autoscan_up(void)
radio_state |= RADIO_AUTOSCAN_UP;
mcu_send_state();
void mcu_autoscan_down(void)
radio_state |= RADIO_AUTOSCAN_DOWN;
mcu_send_state();
void mcu_set_bandfreq(unsigned char band)
if(band == RADIO_FM)
radio_freq = fm_khz/10;
else
radio_freq = fm_khz | ((unsigned int)(band)<<14);
command_buff[0] = (unsigned char)((radio_freq>>8) & 0xff);
command_buff[1] = (unsigned char)(radio_freq & 0xff);
mcu_set_freq(command_buff);
unsigned char temp;
mcu_read_state(receive_data);
temp = receive_data[0];
receive_data[0] = 0;
return temp;
unsigned int temp;
mcu_read_freq(receive_data);
temp = (temp<<8) & 0xff00;
temp |= receive_data[1];
receive_data[1] = 0;
return temp;
void fm_init(void)
//mute fm
fmw_stand_by_rtn(off);
fm_pwr_on;//power on radio
delay720(100);
fm_khz = 87500;
mcu_set_bandfreq(RADIO_FM);
//unmute fm
unsigned char status;
unsigned int freq;
if(dir)
mcu_manuscan_up();
else
mcu_manuscan_down();
unsigned int freq;
if(dir)
mcu_autoscan_up();
else
mcu_autoscan_down();
#else
unsigned char fm_rd_byte[5] = {0,0,0,0,0}; // Read buf
unsigned char fm_wr_byte[5] = {0,0,0,0,0}; // write but
/* ---------------------------------- Command Function ------------------------------------ */
void fmw_hilo_side_rtn(unsigned char hilo)
if(hilo) fm_wr_byte[2] |= 0x10;
else fm_wr_byte[2] &= 0xef;
if(onoff) fm_wr_byte[0] |= 0x80;
else fm_wr_byte[0] &= 0x7f;
void fmw_search_mode_rtn(unsigned char onoff)
if(onoff) fm_wr_byte[0] |= 0x40;
else fm_wr_byte[0] &= 0xbf;
void fmw_search_dir_rtn(unsigned char dir)
if(dir) fm_wr_byte[2] |= 0x80;
else fm_wr_byte[2] &= 0x7f;
void fmw_search_level_rtn(unsigned char level)
switch(level)
case all_level : fm_wr_byte[2] &= 0x9f;
break;
case lo_level : fm_wr_byte[2] &= 0xbf;
fm_wr_byte[2] |= 0x20;
break;
case mid_level : fm_wr_byte[2] |= 0x40;
fm_wr_byte[2] &= 0xdf;
break;
case hi_level : fm_wr_byte[2] |= 0x60;
break;
if(onoff) fm_wr_byte[2] &= 0xf7;
else fm_wr_byte[2] |= 0x08;
void fmw_mute_left_rtn(unsigned char onoff)
if(onoff) fm_wr_byte[2] |= 0x04;
else fm_wr_byte[2] &= 0xfb;
void fmw_mute_right_rtn(unsigned char onoff)
if(onoff) fm_wr_byte[2] |= 0x02;
else fm_wr_byte[2] &= 0xfd;
if(onoff) fm_wr_byte[3] |= 0x40;
else fm_wr_byte[3] &= 0xbf;
void fmw_band_sel_rtn(unsigned char sel)
if(sel) fm_wr_byte[3] |= 0x20;
else fm_wr_byte[3] &= 0xdf;
void fmw_xtal_sel_rtn(unsigned char sel)
if(sel) fm_wr_byte[3] |= 0x10;
else fm_wr_byte[3] &= 0xef;
void fmw_soft_mute_rtn(unsigned char onoff)
if(onoff) fm_wr_byte[3] |= 0x08;
else fm_wr_byte[3] &= 0xf7;
void fmw_hcc_rtn(unsigned char onoff)
if(onoff) fm_wr_byte[3] |= 0x04;
else fm_wr_byte[3] &= 0xfb;
void fmw_snc_rtn(unsigned char onoff)
if(onoff) fm_wr_byte[3] |= 0x02;
else fm_wr_byte[3] &= 0xfd;
void fmw_search_indi_rtn(unsigned char sel)
if(sel) fm_wr_byte[3] |= 0x01;
else fm_wr_byte[3] &= 0xfe;
void fmw_pll_ref_rtn(unsigned char sel)
if(sel) fm_wr_byte[4] |= 0x80;
else fm_wr_byte[4] &= 0x7f;
void fmw_deemph_rtn(unsigned char sel)
if(sel) fm_wr_byte[4] |= 0x40;
else fm_wr_byte[4] &= 0xbf;
unsigned char fmr_ready_flag_rtn(void)
return (unsigned char)((fm_rd_byte[0] >> 7) & 0x01);
unsigned char fmr_band_limit_rtn(void)
return (unsigned char)((fm_rd_byte[0] >> 6) & 0x01);
unsigned short fmr_pll_rtn(void)
unsigned short temp = 0;
temp = (unsigned short)((fm_rd_byte[0] & 0x3f) << 8);
temp |= (unsigned short)fm_rd_byte[1];
return temp;
unsigned char fmr_stereo_indi_rtn(void)
return (unsigned char)((fm_rd_byte[2] >> 7) & 0x01);
unsigned char fmr_if_count_rtn(void)
return (unsigned char)(fm_rd_byte[2] & 0x7f);
unsigned char fmr_level_adc_rtn(void)
return (unsigned char)((fm_rd_byte[3] >> 4) & 0x0f);
/* ------------------------------ End Command function ------------------------------------- */
unsigned char fm_rd_rtn(unsigned char *ptr)
return (unsigned char)(i2c_read((unsigned int)I2C_FM, (unsignedchar)fm_slaveaddr, (char)I2C_SUBADDR_NOUSE, ptr, (unsigned char)5));
return (unsigned char)(i2c_write((unsigned int)I2C_FM, (unsignedchar)fm_slaveaddr, (char)I2C_SUBADDR_NOUSE, ptr, (unsigned char)5));
unsigned char temp;
unsigned short fm_pll_val = 0;
if(hilo) fm_pll_val = (unsigned short)((4000*(fm_freq+225))/32768); // calc PLL decoder
else fm_pll_val = (unsigned short)((4000*(fm_freq-225))/32768);
temp = (unsigned char)((fm_pll_val >> 8) & 0x3f);
fm_wr_byte[0] &= 0xc0;
fm_wr_byte[0] |= temp;
temp = (unsigned char)fm_pll_val;
fm_wr_byte[1] = temp;
fmw_hilo_side_rtn(hilo);
unsigned char temp;
unsigned char levelhigh, levellow;
fmw_pll_rtn(hi_side, fm_freq+450); // Set PLL value High
status = fm_wr_rtn(fm_wr_byte); // Send Command
delay720(20000);
status = fm_rd_rtn(fm_rd_byte); // Read status
levelhigh = fmr_level_adc_rtn(); // Get ADC value
fmw_pll_rtn(hi_side, fm_freq-450); // Set PLL value Low
delay720(20000);
levellow = fmr_level_adc_rtn();
if(levelhigh < levellow) temp = hi_side;
else temp = lo_side;
return temp;
void fm_init(void)
unsigned char i;
#if 0 /* lhm */
i2c_wr
i2c_clk_hi
i2c_data_hi
#endif /* lhm */
// fm_pwr_on // 20050111
delay720(100);
fm_khz = 89100; //107700;
fmw_all_mute_rtn(on); // MUTE OFF
fmw_search_mode_rtn(off); // OFF SearchMode
fmw_search_dir_rtn(up); // Search direction is up
fmw_search_level_rtn(mid_level); // search ADC level is middle
// fmw_search_level_rtn(lo_level); // search ADC level is middle
fmw_stereo_rtn(on); // Steleo ON
fmw_mute_left_rtn(off); // Left force mono off
fmw_mute_right_rtn(off); // Right force mono 0ff
fmw_stand_by_rtn(on); // Stanby off
// fmw_band_sel_rtn(japan); // Japan FM zone
fmw_band_sel_rtn(us_eu); // Japan FM zone
fmw_xtal_sel_rtn(xtal_32768); // set the x-tal to 32.768 KHz
fmw_soft_mute_rtn(on);
fmw_hcc_rtn(on); // HCC ON
fmw_snc_rtn(on); // SNC ON
fmw_search_indi_rtn(on); // Pin 14 is output for the ready flag
fmw_pll_ref_rtn(ref_65_dis); // 6.5Mhz ref. not enable
fmw_deemph_rtn(deemph50); // deemphasis is 50us
i = fm_hilo_optimal(fm_khz); // HILO algorithm -> find optimize PLL
fmw_pll_rtn(i, fm_khz);
fmw_all_mute_rtn(off);
i = fm_wr_rtn(fm_wr_byte);
/*---------------------------------------- Change Hz and Auto Scan ---------------------------------------- */
if(dir)
if(fm_khz >= 108000) fm_khz = 87500;
else fm_khz += scan_step;
else
if(fm_khz <= 87500) fm_khz = 108000;
else fm_khz -= scan_step;
status = fm_hilo_optimal(fm_khz);
fmw_pll_rtn(status, fm_khz);
//fmw_all_mute_rtn(off); // TEST
//LCD_DisplayChannelForFM(fm_khz);
unsigned char status, curlev, curifc;
if(dir)
else
//fmw_all_mute_rtn(on); // TEST
status = fm_wr_rtn(fm_wr_byte); // Edit By Jim
// delay720(20000);
delay720(30000);
curlev = fmr_level_adc_rtn();
curifc = fmr_if_count_rtn();
// LCD_DisplayChannelForFM(fm_khz);
if(fm_khz == 88000)
fm_khz = 88000;
else if(fm_khz == 89100)
fm_khz = 89100;
else if(fm_khz == 89700)
fm_khz = 89700;
else if(fm_khz == 91900)
fm_khz = 91900;
else if(fm_khz == 93100)
fm_khz = 93100;
else if(fm_khz == 93900)
fm_khz = 93900;
else if(fm_khz == 95100)
fm_khz = 95100;
else if(fm_khz == 95700)
fm_khz = 95700;
else if(fm_khz == 95900)
fm_khz = 95900;
else if(fm_khz == 97300)
fm_khz = 97300;
else if(fm_khz == 98100)
fm_khz = 98100;
else if(fm_khz == 99100)
fm_khz = 99100;
else if(fm_khz == 99600)
fm_khz = 99600;
else if(fm_khz == 100000)
fm_khz = 100000;
else if(fm_khz == 101100)
fm_khz = 101100;
else if(fm_khz == 101900)
fm_khz = 101900;
else if(fm_khz == 102700)
fm_khz = 102700;
else if(fm_khz == 103500)
fm_khz = 103500;
else if(fm_khz == 105300)
fm_khz = 105300;
else if(fm_khz == 106100)
fm_khz = 106100;
else if(fm_khz == 106900)
fm_khz = 106900;
else if(fm_khz == 107700)
fm_khz = 107700;
// if((curlev > 3) && (0x30 < curifc) && (curifc < 0x3c) ) return 1; // scan_level
else
return 0;
unsigned char status, i;
unsigned char index = 1; // Edit By Jim
unsigned int dumy_fm_khz = fm_khz;
for(i=0;i<10;i++)
if(fm_auto_scan(dir)) index++;
else break;
if(index%2)
if(dir) fm_khz = dumy_fm_khz + (unsigned int)((index/2)*100);
else fm_khz = dumy_fm_khz - (unsigned int)((index/2)*100);
else
if(dir) fm_khz = dumy_fm_khz + (unsigned int)(((index/2)-1)*100);
//fmw_all_mute_rtn(off); TEST
// LCD_ClearOneLine(2);
// lcd_var(0, 2, fm_khz);
return fm_khz;
#endif
#endif
/*以下是FM.h*/
/* MODULE: */
FM.h
* TCC Version 0.0
//dddxxx
#include "tcc760.h"
#ifdef RADIO_MCU
enum{
PRESET_MODE_OFF,
PRESET_MODE_ON,
NO_MODE,
MANUAL_ADD_CH
#define off 0
#define on 1
#define up 1
#define down 0
} FMRADIO;
#else
enum{
PRESET_MODE_OFF,
PRESET_MODE_ON,
NO_MODE,
MANUAL_ADD_CH
#define off 0
#define on 1
#define up 1
#define down 0
#define all_level 0
#define lo_level 1
#define mid_level 2
#define hi_level 3
} FMRADIO;
#endif
/* MODULE: */
/* FM.c
* TCC Version 0.0
#include "main.h"
#include "fm/FM.h"
FMRADIO RadioData;
#ifdef RADIO_MCU
// if(onoff)
// fm_pwr_on;
// else
// fm_pwr_off;
if(onoff)
mcu_send_state();
//if(onoff)
if(onoff)
mcu_send_state();
mcu_send_state();
mcu_send_state();
mcu_send_state();
mcu_send_state();
else
unsigned char temp;
return temp;
unsigned int temp;
return temp;
void fm_init(void)
//mute fm
delay720(100);
fm_khz = 87500;
//unmute fm
unsigned int freq;
if(dir)
mcu_manuscan_up();
else
unsigned int freq;
if(dir)
mcu_autoscan_up();
else
#else
switch(level)
break;
break;
break;
break;
return temp;
unsigned char temp;
unsigned char temp;
delay720(20000);
delay720(20000);
return temp;
void fm_init(void)
unsigned char i;
#if 0 /* lhm */
i2c_wr
i2c_clk_hi
i2c_data_hi
#endif /* lhm */
delay720(100);
if(dir)
else
if(dir)
else
// delay720(20000);
delay720(30000);
if(fm_khz == 88000)
fm_khz = 88000;
fm_khz = 89100;
fm_khz = 89700;
fm_khz = 91900;
fm_khz = 93100;
fm_khz = 93900;
fm_khz = 95100;
fm_khz = 95700;
fm_khz = 95900;
fm_khz = 97300;
fm_khz = 98100;
fm_khz = 99100;
fm_khz = 99600;
fm_khz = 100000;
fm_khz = 101100;
fm_khz = 101900;
fm_khz = 102700;
fm_khz = 103500;
fm_khz = 105300;
fm_khz = 106100;
fm_khz = 106900;
fm_khz = 107700;
else
return 0;
for(i=0;i<10;i++)
else break;
if(index%2)
else
return fm_khz;
#endif
#endif
/*以下是FM.h*/
/* MODULE: */
FM.h
* TCC Version 0.0
//dddxxx
#include "tcc760.h"
#ifdef RADIO_MCU
enum{
PRESET_MODE_OFF,
PRESET_MODE_ON,
NO_MODE,
MANUAL_ADD_CH
#define off 0
#define on 1
#define up 1
#define down 0
} FMRADIO;
#else
enum{
PRESET_MODE_OFF,
PRESET_MODE_ON,
NO_MODE,
MANUAL_ADD_CH
#define off 0
#define on 1
#define up 1
#define down 0
#define all_level 0
#define lo_level 1
#define mid_level 2
#define hi_level 3
} FMRADIO;
#endif
/* MODULE: */
/* FM.c
* TCC Version 0.0
#include "main.h"
#include "fm/FM.h"
FMRADIO RadioData;
#ifdef RADIO_MCU
// if(onoff)
// fm_pwr_on;
// else
// fm_pwr_off;
if(onoff)
mcu_send_state();
//if(onoff)
if(onoff)
mcu_send_state();
mcu_send_state();
mcu_send_state();
mcu_send_state();
mcu_send_state();
else
unsigned char temp;
return temp;
unsigned int temp;
return temp;
void fm_init(void)
//mute fm
delay720(100);
fm_khz = 87500;
//unmute fm
unsigned int freq;
if(dir)
mcu_manuscan_up();
else
unsigned int freq;
if(dir)
mcu_autoscan_up();
else
#else
switch(level)
break;
break;
break;
break;
return temp;
unsigned char temp;
unsigned char temp;
delay720(20000);
delay720(20000);
return temp;
void fm_init(void)
unsigned char i;
#if 0 /* lhm */
i2c_wr
i2c_clk_hi
i2c_data_hi
#endif /* lhm */
delay720(100);
if(dir)
else
if(dir)
else
// delay720(20000);
delay720(30000);
if(fm_khz == 88000)
fm_khz = 88000;
fm_khz = 89100;
fm_khz = 89700;
fm_khz = 91900;
fm_khz = 93100;
fm_khz = 93900;
fm_khz = 95100;
fm_khz = 95700;
fm_khz = 95900;
fm_khz = 97300;
fm_khz = 98100;
fm_khz = 99100;
fm_khz = 99600;
fm_khz = 100000;
fm_khz = 101100;
fm_khz = 101900;
fm_khz = 102700;
fm_khz = 103500;
fm_khz = 105300;
fm_khz = 106100;
fm_khz = 106900;
fm_khz = 107700;
else
return 0;
for(i=0;i<10;i++)
else break;
if(index%2)
else
return fm_khz;
#endif
#endif |
