查看: 1582|回复: 0
[招聘] Cadence上海招EDA软件开发工程师
发表于 2014-3-4 17:03:10 | 显示全部楼层 |阅读模式
Shanghai研发职位
工作地点:上海市浦东新区浦东嘉里城
联系邮箱:cecilyl@cadence.com
1.  Senior Member of Technical Staff- Routing 1 Vacancy
      Position Description:
-Responsible fordevelopment and maintenance of signal routing in EDI platform (NanoRoute).
-Implementation forcomplicated advanced node design rule support in NanoRouter.
-New feature support andperformance improvement in NanoRoute.
      Position Requirements:
-MS above in CS/EE orsimilar level of expertise with 3+ years of working experience.
-Be skilled in C/C++programming on Linux platform.
-Good team player with strongwritten and verbal communication skills.
-Familiar with the routingalgorithm (maze routing) is preferred.
-Familiar with LEF/DEF ispreferred.
2.  Senior Member of Technical Staff- CTS 1 Vacancy
-R&D engineer to do the clock treesynthesis related works (product maintain, software development, design flowimprovement etc.)
-MS or PhD in EE/CS etc.
-Excellent programming skills (C/C++, script)
-The following background is preferred: EDA, ICphysical design, CTS, Timing analysis, Optimization.
-Good written and spokenEnglish
-Goodcommunication skills and be able to work within a team.
3.  Senior Member of Technical Staff- Placement
1 Vacancy
      PositionDescription:
-The primary responsibility is designing,  developing, troubleshooting and debugging software programs on Unix/Linux  platforms. Will be involved in placement development for Encounter.
      PositionRequirements:
-The candidates should havestrong software programming skill with C/C++ and EDA backend knowledge.
-Strong interest andunderstanding of complex software development in UNIX platform are required
-Good verbal and writtenpresentation are must
-Minimum master degrees inEE or CS
4.Senior SoftwareEngineer for IPO3 Vacancies
-Work on EDI IPO function on CCR fixing, memory and performanceprofiling as well as new enhancements
-Logic synthesis background
-MS/PHD from computer science,EE, math or related
-Multi-thread programmingbackground
-Timing background
-Physical placement background orclock tree synthesis background
-Very solid at C programming
-Good English communication skill
5. Senior Member of Technical staff-Floor Plan 1 Vacancy
-The candidatewill be a member of the Encounter floorplan team in Shanghai, to work on thedevelopment and maintenance of manual Floorplan project.
-Theresponsibilities include the develop of new features and products, and supportother teams in Encounter product lines.
-The candidatemust be comfortable working with existing code as well as developing newfunctionality to address new requirements, and be working closely withlocal/remote team members, and be also strong technical support to team.
-Candidate mustbe an expert in software engineering methods and committed to high quality ofdevelopment work.
-The individualmust be team-oriented, possess good communication skills, self-motivated, ableto work independently and working with a team from multiple remote sites.
-Candidate mustbe able to develop detailed technical specification as well as the ability toscope efforts required.
-The candidatemust be also smart to capture new EDA technologies, and switch among differentareas successfully.
-Advanceddeveloping and debugging software in UNIX & LINUX environments, familiar with gnu c/c++, gdb etc..
-Strongproblem-solving, architecture, algorithmic.
-Familiar withinterpreted language such as TCL is a plus.
-Knowledge ofDigital Physical Design flow such as Floorplan/Placement/Routing/CTS isa plus.
GMT+8, 2025-12-25 13:14 , Processed in 0.030916 second(s), 7 queries , Gzip On, Redis On.
