查看: 3187|回复: 1
[求助] interface 多驱动错误
发表于 2014-2-25 13:55:47 | 显示全部楼层 |阅读模式
module test_top;
     test_if    u1_test_if();
     test_int  u_test_int();
     assign u1_test_if.u_test_if1.abc=1'b0;
endmodule
module test_int;
    test_if u2_test_if();
    assign u2_test_if.u_test_if1.abc=1'b1;
endmodule
interface test_if();
   test_if1 u_test_if1();
endinterface
interface test_if1();
   logic abc;
endinterface
编译上面的代码后报错:
Error-[ICSD] Combination of structural drivers
test_top.sv, 18
Invalid combination of structural drivers
Variable "abc" is driven by multiple structural drivers.
"test_top.sv", 18: logic abc;
"test_top.sv", 5: assign u1_test_if.u_test_if1.abc=1'b0;
"test_top.sv", 10: assign u2_test_if.u_test_if1.abc=1'b1;
求解~~~
 楼主| 发表于 2014-2-25 17:15:03 | 显示全部楼层
如果test_if不再包test_if1,就没有问题,如下:
module test_top;
     assign u1_test_if.abc=1'b0;
endmodule
module test_int;
    assign u2_test_if.abc=1'b1;
endmodule
   //test_if1 u_test_if1();
    logic abc;
endinterface
GMT+8, 2025-11-27 11:26 , Processed in 0.027601 second(s), 6 queries , Gzip On, Redis On.
