楼主: bu2zhouzhu
Micro-Cap 11 Evaluation Version
发表于 2015-5-27 09:56:49 | 显示全部楼层
More powerful
Numerous features contribute to Micro-Cap 11's power. Among them are:
•Integrated schematic editor and simulator.
•Dynamic analysis updates waveforms and curves as you edit
•Native digital simulator
•Worst Case analysis to find the statistical and extreme limits of performance
&#8226eriodic Steady State analysis
•Integral circuit optimizer with multiple optimization methods.
•Integrated active and passive filter design function
•Device library with over 32,000 parts.
• Analog and digital behavioral modeling
• Schematic waveform probing.
•On-schematic voltage/state, current, power, and condition display
•During the run plotting
• Smith charts / Polar plots.
• Multidimensional parameter stepping.
• Monte Carlo analysis.
• 3D plotting.
&#8226erformance functions and plots
•.Measure functions to measure circuit behavior
•Optimizing parts modeler
•Gummel-Poon, Mextram and Modella bipolar models
•Berkeley BSIM 1, BSIM 2, BSIM3, and BSIM4 MOSFET models
•The latest Philips device models, including MOS 11, 20, 31, 40, and PSP 102
•Hefner IGBT model
•IBIS model translator
•Animated LEDs, switches, bars, meters, relays, stoplights, and DC motors
•Sample and hold, timer, and Z transform devices
•Lossy transmission lines
•Jiles-Atherton nonlinear magnetics model
&#8226CB interface to popular packages
•LAN version for collaborative projects
• Transient analysis - for investigating time domain circuit behavior
• AC analysis - for investigating small signal behavior
• DC analysis - for plotting static DC variables
• Transfer Function analysis - for calculating the DC transfer function
• Stability analysis - to find the stability limits for linear circuits
•Harmonic distortion analysis
•Intermodulation distortion analysis
• Extensive mathematical operators and variables.
不过 10版本可以在线升级,但是完成后,不让你用了,哈哈。
发表于 2015-6-2 15:59:37 | 显示全部楼层
It's Full or semi-full?
发表于 2015-7-25 10:50:56 | 显示全部楼层
发表于 2015-7-25 13:55:34 | 显示全部楼层
这个软件只能小版本升级,而且每次都要破解。
大版本不提供免费下载,需要完全版本才能破解。
也不知4楼orlyonok提供的是否为完全版,如果是的话,可以找人破解。。
这个软件我用了好几年了,算是比较熟悉。只是电子技术基础差,只会一些应用级的东西
发表于 2015-7-26 10:03:37 | 显示全部楼层
Great, Thanks
发表于 2015-8-14 23:15:07 | 显示全部楼层
zenme anzhuang
发表于 2015-10-17 21:10:57 | 显示全部楼层
你有安装程序吗?我可以试试帮你破解
发表于 2015-10-21 13:07:53 | 显示全部楼层
filling water
发表于 2015-10-21 13:21:55 | 显示全部楼层
filling water
发表于 2015-10-21 13:24:41 | 显示全部楼层
filling water
GMT+8, 2025-12-28 23:22 , Processed in 0.025315 second(s), 3 queries , Gzip On, Redis On.
