查看: 1754|回复: 0
[招聘] NO.73-Principle SI/PI Engineer(Shanghai)
发表于 2014-2-12 16:26:34 | 显示全部楼层 |阅读模式
Position Description:
Complete power-delivery system analyses across chips, packages and boards. System-level SI analysis, including simultaneous switching noise analysis of high-speed signal transmissions, and advances physical design for single- and multi-chip packages, states-of-the-art 3D packages, and systems in packaged (SiP). The engineer should be able to act as a strong team member and contributor.
Specific duties include:
- Be responsible for building SI/PI/SiP design flow for High-speed IP Design
- Proficiency in Cadence tools: Allegro and Sigrity
- Proficiency in Hspice or spectre simulation, especially in high-speed simulation.
- Good knowledge in modeling, for example IBIS.
- Good knowledge in high-speed PCB design.
- At least eight years experience focus on SiP and SI/PI analysis, excellent communication skills and the uncanny ability to both lead and contribute in a cooperative team environment is required.
Position requirements:
Essential Qualifications:
1. Must have BS degree with 10+ years of applicable experience, MS degree with 7+ years of applicable experience in electrical engineering, microelectronics, comparable engineering science or solid state physics.
2. Essential that the individual demonstrates strong communication, verbal and written. Requires good communication skills in English.
Desirable Qualifications:
A  minimum of seven years relevant experience in industry.
- At least five years experience driving SiP/PI/SI project.
- Will have demonstrated successful completion of 10+ projects as an individual contributor
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-25 04:53 , Processed in 0.010945 second(s), 3 queries , Gzip On, Redis On.
