查看: 2794|回复: 3
[求助] 求ieee文章一篇,谢谢!
发表于 2014-2-11 16:24:24 | 显示全部楼层 |阅读模式
Efficient technique for excess loop delay compensation in continuous-time ΔΣ modulators
A highly digital technique is proposed for excess loop delay (ELD) compensation in multi-bit continuous-time ???? modulators. A digitally controlled reference switching matrix is used to replace the powerhungry signal adder and extra DAC driving the quantiser, which are commonly used in ELD compensation. With the proposed technique, the feedback DAC is embedded in the quantiser and implemented by a few switches. Thus, it allows low-voltage and low-power operation.
http://ieeexplore.ieee.org/xpl/articleDetails.jsp?arnumber=6680410
thanks a lot!
发表于 2014-2-11 17:00:31 | 显示全部楼层
Efficient technique for excess loop delay compensation in continuous-time ΔΣ modulators.pdf (403.35 KB , 下载次数: 24 )
发表于 2015-12-30 12:20:19 | 显示全部楼层
正需要,多谢分享
发表于 2017-8-22 11:35:24 | 显示全部楼层
kankan duoxie
GMT+8, 2025-12-14 03:35 , Processed in 0.018983 second(s), 7 queries , Gzip On, Redis On.
