Cadence SH 招聘 Principle SI/PI Engineer (信号完整性工程师) 更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your updateCV to zhangyl@cadence.com Position Description: Completepower-delivery system analyses across chips, packages and boards. System-levelSI analysis, including simultaneous switching noise analysis of high-speedsignal transmissions, and advances physical design for single- and multi-chippackages, states-of-the-art 3D packages, and systems in packaged (SiP). Theengineer should be able to act as a strong team member and contributor. Specific dutiesinclude:
- Beresponsible for building SI/PI/SiP design flow for High-speed IP Design - Proficiencyin Cadence tools: Allegro and Sigrity -
Proficiencyin Hspice or spectre simulation, especially in high-speed simulation.
Goodknowledge in modeling, for example IBIS. -
Goodknowledge in high-speed PCB design. -
Atleast eight years experience focus on SiP and SI/PI analysis, excellentcommunication skills and the uncanny ability to both lead and contribute in acooperative team environment is required.
Position requirements: EssentialQualifications: 1.
Musthave BS degree with 10+years of applicable experience, MS degree with 7+years of applicable experience
inelectrical engineering, microelectronics, comparable engineering science orsolid state physics. 2.
Essentialthat the individual demonstrates strong communication, verbal and written.Requires good communication skills in English. DesirableQualifications: A
minimumof seven years relevant experience in industry. - At least five yearsexperience driving SiP/PI/SI project. - Will have demonstratedsuccessful completion of 10+ projects as an individual contributor |
