查看: 3037|回复: 2
[求助] the summing circuit does not work
发表于 2014-2-6 18:52:33 | 显示全部楼层 |阅读模式
summing circuit
summing circuit
I want to realize this summing circuit based on feedback opamp for input signals of 10G. I just write a verilog A opamp for simulation, but the circuit seems not work. I am confused about how to bias this circuit and is that right to just connect the positive input to groud? what's more , how to choose the resistors here? thanks very much.
发表于 2014-2-8 12:42:12 | 显示全部楼层
first, check whether  the opamp model you designed works well
 楼主| 发表于 2014-2-9 23:51:16 | 显示全部楼层
回复 2# rong00i8
I think it goes well. I pay most attention to the Gain and bandwidth in the model with one pole. I check it before and after adding the feedback.
GMT+8, 2025-12-28 12:31 , Processed in 0.018599 second(s), 7 queries , Gzip On, Redis On.
