查看: 2229|回复: 0
[招聘] NO.314-Senior Digital Design Engineer(Hongkong)
发表于 2014-1-21 17:16:10 | 显示全部楼层 |阅读模式
Job Responsibilities:
    Perform logic design, RTL coding, design verification, logic synthesis, DFT and static timing analysis
    Develop verification environment and coverage closure
    Support wafer level testing and silicon evaluation
    Prepare technical documents
Job Requirements:
    B.Sc or above in Electronic Engineering or equivalent. Applicants with postgraduate degree would be considered as an advantage
    5 Years or above of solid experience in one or more of the following areas: Verilog-based logic design and synthesis, constrained random    testbench with System Verilog & UVM, assertion based design verification or circuit-level SPICE simulations
    Knowledge of SoC and embedded system.
    Knowledge of scripting languages such as Perl, TCL and Make
    Candidate with less experience will be considered as Digital Design Engineer
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-15 06:23 , Processed in 0.031882 second(s), 6 queries , Gzip On, Redis On.
