查看: 2639|回复: 4
[求助] 跪求 cadence615 verilog仿真问题
发表于 2014-1-14 20:51:16 | 显示全部楼层 |阅读模式
cadence615 使用的是mmsim10 仿真器,但是进行不了verilog 仿真   截图00.png 出现这样的报错
有没有人遇见过  怎么解决?
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/890_work61_PADCHLMC_DA12_veriloga_veriloga.va.d2a_ideal.ahdlcmi/Linux2.6.9-89.ELlargesmp+gcc/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
发表于 2014-1-15 03:44:16 | 显示全部楼层
INSTALL GLIBC
 楼主| 发表于 2014-1-16 21:45:09 | 显示全部楼层
 楼主| 发表于 2014-1-16 21:45:26 | 显示全部楼层
INSTALL GLIBC
mabas.masood 发表于 2014-1-15 03:44
    谢谢你的回答,我明白不你的意思,帮我讲详细一些好吗?
 楼主| 发表于 2014-1-16 21:47:13 | 显示全部楼层
INSTALL GLIBC
   谢谢你的回答,可否讲详细一些,我不是很明白你的意思,谢谢你
GMT+8, 2025-12-19 09:43 , Processed in 0.021885 second(s), 7 queries , Gzip On, Redis On.
