查看: 1585|回复: 0
[招聘] Cadence SH 招聘Lead PV Engineer (Block implementation)
发表于 2014-1-10 16:03:16 | 显示全部楼层 |阅读模式
Title: Lead PV Engineer (Block implementation) (Location: SH)
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your update CV to zhangyl@cadence.com
Position Description:
1.This job is an important addition to our R&D team to develop Cadence Encounter Digital Implementation System (EDI)
2.Responsible for developing, applying, and improving quality standard for Cadence EDI products
3.Required to acquire expertise and ownership over existing product components as well as develop brand new product features.
4.Help identifying new technology challenges in advanced process nodes and proactively provide the product improvement suggestion to R&D
5.Build up EDI expertise and deliver support to field team and customers whenever needed
Position Requirements:
1.CS/EE BS degree with 3+ years or MS degree with 1+ years of EDA or IC design related experience.
2.Good experience with Place and Route design flow using EDA tools. Good knowledge of LEF/DEF.
3.Be familiar with IC back-end design flow, from net list to gdsout.
4.Strong analysis/debug capability for technical issues, be detailed oriented with a focus on quality.
5.Good team player with strong written and verbal communication skills.
6.Be able to work under pressure, be able to work on multiple projects at the same time.
Good English read, write and communication Skill.
GMT+8, 2025-12-24 21:09 , Processed in 0.016917 second(s), 6 queries , Gzip On, Redis On.
