查看: 30512|回复: 102
[资料] IEEE模拟集成电路经典论文合集(大压缩包,有目录)
发表于 2014-1-10 10:56:05 | 显示全部楼层 |阅读模式
目录
A rail to rail CMOS Amp  by Joseph N.Baranezhad 1988
Amplifier structure for high gain and fast setting applications by A.E. Hashim
MOS Operational Amplifier Design - A Tutorial Overview  by P. E. Allen 1982
Low Voltage Techniques by Robert J. Widlar 1978
Relationship between frequency response and settling time of OpAmps by B. Y. Kamath 1974
Impact of Scaling on MOS Analog Performance by Stephen Wong 1983
A high performance low power CMOS channel filter
A low dropout CMOS regulator with high PSR over wideband frequencies
An NMOS OpAmp with internal compensation
Efficient pole zero sensitivity analysis using asymptotic waveform evaluation
Indirect feedback compensation of CMOS OpAmps
Miller OTA design using a design methodology based on the gm-id and early-voltage characteristics
Phase compensation for feedforward CMOS OTA
Phase compensation scheme for feedforward linearized CMOS OTA
An improved frequency compensation tech for CMOS OpAmps by B. K. Ahuja 1983
CMOS technology characterization for analog and RF design by Behzad Razavi 1999
Three Stage Amplifier Frequency Compensation by Willy Sansen
A curvature-corrected low-voltage bandgap reference by Joban H. Huijsing 1993
Small-signal analysis and minimum settling time design of a one-stage folded-cascode CMOS
operational amplifier  by David J. Allstot 1991
Accurate two-transistor current mirrors by P.E. Allen 1994
A Continuous-Time CMFB for High-Impedance Current Mode App
A Linear MOS Transconductor using Source Degeneration and Adaptive Biaing
Fully Differential OpAmp with Accurate Output Balance
A 3V CMOS low-distortion class AB line driver suitable for HDSL applications
A capacitance-compensation Tech for improved linearity in CMOS class-AB power amp
A class AB output buffer for driving high capacitive loads
A classAB floating buffer BiCMOS Op-Amp
A class-AB floating buffer BiCMOS power OpAmp
High-voltage OpAmp based on dual floating-gate transistors
A novel class AB transconductor suitable for high speed CMOS OpAmp
Low voltage class AB output stages for CMOS op-amps using floating capacitors
IEEE经典论文合集.part1.rar
9.54 MB, 下载次数: 1375 , 下载积分: 资产 -4 信元, 下载支出 4 信元
IEEE经典论文合集.part2.rar
6.38 MB, 下载次数: 1273 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2014-1-10 11:05:38 | 显示全部楼层
太好了,顶楼主一个
发表于 2014-1-10 11:07:40 | 显示全部楼层
不错
发表于 2014-1-10 11:11:56 | 显示全部楼层
好东西要支持
发表于 2014-1-10 11:55:52 | 显示全部楼层
好东西,支持一个
发表于 2014-1-10 19:39:17 | 显示全部楼层
好东西啊,谢谢楼主收集那么多精品
发表于 2014-1-10 19:54:25 | 显示全部楼层
楼主做个好事,能分个类可以不,密密麻麻的
发表于 2014-1-11 18:27:28 | 显示全部楼层
好东西要支持
发表于 2014-1-11 18:52:33 | 显示全部楼层
多谢楼主
发表于 2014-1-11 19:50:02 | 显示全部楼层
给楼主赞一个~
GMT+8, 2025-12-28 20:08 , Processed in 0.024304 second(s), 8 queries , Gzip On, Redis On.
