查看: 1563|回复: 0
怎么证明这个系统是线性的?
发表于 2014-1-7 23:00:15 | 显示全部楼层 |阅读模式
The initial reset assumption corresponds toa zero-valued auxiliary condition/being imposed at a time determined inaccordance with the input signal. In the problem we show that if the auxiliarycondition used is nonzero, or if it is always applied at a fixed-time(regardlessof the input signal)the corresponding system can not be LTI. Consider a systemwhose input x(t)and output y(t)satisfy the first-order differential equation dy(t)/dt+2y(t)=x(t).
Given the auxiliary condition y(0)+y(4)=0,showthat the system is linear but not time invariant.
GMT+8, 2025-12-25 22:31 , Processed in 0.011867 second(s), 3 queries , Gzip On, Redis On.
