查看: 2486|回复: 8
Synplify Problem
发表于 2014-1-4 23:30:51 | 显示全部楼层 |阅读模式
Guide me...
Have problem in both windows and linux..
Help me how to solve the problem
Synplify pro
Synplify pro
 楼主| 发表于 2014-1-5 16:58:13 | 显示全部楼层
回复 2# 卖女孩的小火柴
   ok darling no prob....
Have any idea to solve this issue..?
 楼主| 发表于 2014-1-6 12:46:50 | 显示全部楼层
can you solve this issue?
 楼主| 发表于 2014-1-10 14:15:48 | 显示全部楼层
回复 4# 卖女孩的小火柴
   can you sove tjis issue.......
发表于 2014-1-22 03:10:48 | 显示全部楼层
我可以解决,可以邮件联系我,565526418@qq.com
发表于 2014-1-31 20:43:12 | 显示全部楼层
me too
发表于 2014-2-1 02:21:39 | 显示全部楼层
for debugging -
go to command window (cmd.exe); and type set
make sure all license variable point to correct license file (there may be 3)
if not type in
set LM_LICENSE_FILE= path to your license file
set SYNPLCTYD_LICENSE_FILE=path to your license file
set SNPSLMD_LICENSE_FILE=path to your license file
start taskmgr, and kill all lmgrd process
then manually start lmgrd
cd \synopsys\scl\11.x\win32\bin
lmgrd -c path to license file
then manually start synplify_premier or whatever using cmd line
for example do
cd \synopsys\fpga_I...\bin
synplify_premier
发表于 2014-2-1 05:58:51 | 显示全部楼层
you forbid your MAC.
 楼主| 发表于 2014-2-1 19:03:08 | 显示全部楼层
I need for windows version
GMT+8, 2025-12-21 12:59 , Processed in 0.020820 second(s), 7 queries , Gzip On, Redis On.
