查看: 3029|回复: 3
[原创] 【K70例程】005观察点和跟踪数据Data Watchpoint and Trace(DWT)_IAR
发表于 2013-12-24 15:20:19 | 显示全部楼层 |阅读模式
dwt简介Data Watchpoint and Trace (DWT)
Data Watchpoint and Trace (DWT) for real-time variable monitoring and PC-sampling, which can in turn be used to periodically output the PC or various CPU-internal counters, which can be used to obtain profiling information from the target.
使用J-LinkV8
IAR版本6.6
调试串口波特率:115200
基于MDKK70-EK_T43硬件平台
关键词: Freescale 飞思卡尔 Kinetis Cortex-M4 K70 MDKK70 核心板 开发板 例程 DWT
串口输出:
//在没有仿真的情况下进入Debug中断
External Pin Reset
K70-256pin      Silicon rev 1.0
Flash parameter version 0.0.8.0
Flash version ID 1.0.18.0
DWT watchpoint demo!!
Hit any key to start
set dwt watchpoint
//此时程序发生仿真中断,LED_D31灯亮起
****default_isr entered on vector 12*****
comparator match
//进行仿真时
Software Reset
set dwt watchpoint
//此时程序仿真发生中断,LED_D31灯亮起,按IAR下按F5继续运行程序
comparator match
简单的说就是设置好触发源,在希望输出调试信息的地方操作触发源触发该中断。
 楼主| 发表于 2013-12-24 15:21:07 | 显示全部楼层
 楼主| 发表于 2013-12-24 15:22:21 | 显示全部楼层
 楼主| 发表于 2013-12-24 15:23:40 | 显示全部楼层
005观察点和跟踪数据Data Watchpoint and Trace(DWT)_IAR.rar (2.11 MB , 下载次数: 3 )
GMT+8, 2025-10-7 03:38 , Processed in 0.017088 second(s), 4 queries , Gzip On, Redis On.
