楼主: asueee
[下载]cadence ic design 5.0.3.3
 楼主| 发表于 2005-11-24 12:39:57 | 显示全部楼层
i am not crazy, i know that there are three CDs and more than 1.5GB.However, this is program is very demanding to many people. Right now, all electrical softwares could be downloaded, but this one is an exception. I did download two CDs from 51eda.coom, but no CD3 and license. If you could upload CD3 and the license file, I will greatly appreciate it. Looking forwards to your support.
Regards.
发表于 2005-11-24 13:35:16 | 显示全部楼层
Sorry, I can not help you to upload anything. You have downloaded the soft from ed@51. I know it works.
You should not try to set up it on FC4. It always failed. If you have installed eveything (Huge, but no other choice) when set up FC4, the soft can be installed. But something is still wrong. You should install it on RH7.x. It's perfect.
And you can search the lic though the internet.
 楼主| 发表于 2005-11-24 23:52:31 | 显示全部楼层
thanks for your reply. but 51eda has only cd 1 and 2 and two additional patch CDs for these two CDs, CD 3 is still missing. Someone told there are three CDs in total for 5.033. Have you tried it? Could you also pose the licence file here? i did search internet, but no result. Looking forwards to your help.
Regards
 楼主| 发表于 2005-12-2 09:27:56 | 显示全部楼层
could you burn me the cds? thanks.
发表于 2005-12-2 19:32:56 | 显示全部楼层
I suggest you download a e-mule from www.emule.org or www.emule.org.cn.
Then search IC5.0 from the sever. You will find a package that is 2.6GB.
I'm not sure that the crack included with it can work or not. You should try.
发表于 2006-3-30 22:07:29 | 显示全部楼层
emule,it's ok,but there's not enough people to share the document
发表于 2006-10-12 00:31:34 | 显示全部楼层
thanks for your information...
thanks.....
发表于 2006-11-21 12:35:27 | 显示全部楼层
很好,多谢!!!
发表于 2006-12-2 06:51:09 | 显示全部楼层
请好心人上传万众期待的cadence IC 5.033.
发表于 2007-10-8 04:58:47 | 显示全部楼层
I do need the software too!
GMT+8, 2025-12-20 14:17 , Processed in 0.017556 second(s), 3 queries , Gzip On, Redis On.
