查看: 4208|回复: 5
[讨论] 环形振荡器全差分的结构,用两级可以吗?
发表于 2013-12-2 14:30:15 | 显示全部楼层 |阅读模式
拉扎维书上说不行,要无穷大频率才能相移360. 不过看一些文章有出现2级的环形振荡器。请大牛来说说
发表于 2013-12-2 18:22:28 | 显示全部楼层
我确实也见过。把电路的寄生极点搞大,应该是有可能的。不过可能有不起振的风险,而且设计不好,相噪也会很差。
发表于 2013-12-2 19:14:33 | 显示全部楼层
It's OK to use 2-stage differential oscillator to generate IQ phase. 2 stage differential oscillator is actually have 4 Gm cells, so it is more than enough to have 360 phase shift.
However, you need to know the working principle for differential oscillator is somehow different to single end oscillator.
the most common 2 stage differential oscillator is for latch based fully CMOS INV structure.
发表于 2013-12-4 11:16:56 | 显示全部楼层
两级当然可以了
自身的反相180*2,两个极点90*2,total max phase shift 540
发表于 2013-12-4 17:36:40 | 显示全部楼层
三楼说的对。
发表于 2021-8-11 10:28:06 | 显示全部楼层
GMT+8, 2025-12-14 11:12 , Processed in 0.018062 second(s), 5 queries , Gzip On, Redis On.
