在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 7556|回复: 5
[求助] Cadence里面基于RLCG模型的传输线
发表于 2013-10-20 08:38:57 | 显示全部楼层 |阅读模式
请问在Cadence里面有没有基于RLCG模型的传输线? 眼前想做个仿真,但是只有RLCG参数,是个有损的理想传输线。在AnalogLib里面有tline model, 但是也需提供delay, electrical length等常数,请问可以从RLCG进行转换吗?
Ps:级联形式的近似已经试过了,因为级联近似的有限带宽的原因,所以想直接做出传输线进行仿真。
谢谢大家!
发表于 2013-10-20 11:44:00 | 显示全部楼层
use mtline in analogLib, have fun.
发表于 2015-1-21 20:31:51 | 显示全部楼层
回复 1# liuqilong8819
   你好,请问如何获取RLCG的参数数据。   我也想用mtline做个背板传输的建模,但mtline设置里选择RLCG的话要求给RLCG data file,不晓得这个file可以从何而来。
   或者mtline其他选项楼主知不知道如何进行建模、?
 楼主| 发表于 2015-1-21 20:52:04 | 显示全部楼层
回复 3# PERRY_C
   Hi Perry_C,   I use a vector network analyzer (VNA) to measure the S parameters, then convert them to RLCG model. The conversion can be done manually (via Pozar's textbook), or by using a software such as ADS.
   Another thing about RLCG model is, it is more accurate in time-domain simulation. If you prefer to get the frequency domain information, then other TL model are also OK. For the details please refer to the application note released by Cadence.
   Good luck!
Qilong
发表于 2015-1-21 23:13:33 | 显示全部楼层
回复 4# liuqilong8819
   Thank you for your reply !
   I have no idea with VNA before...
   But I think I can get what I want from ADS or HFSS~
    The Cadence application note also helps me much.
    Thanks again~^_^
发表于 2015-1-21 23:17:21 | 显示全部楼层
回复 4# liuqilong8819
   Thank you for your reply!   I have no idea with VNA befor ...
   Thanks again ~^_^
小黑屋| 手机版| 关于我们| 联系我们| 在线咨询| 隐私声明| EETOP 创芯网
GMT+8, 2024-11-17 01:48 , Processed in 0.028001 second(s), 9 queries , Gzip On, Redis On.
