查看: 1258|回复: 0
[招聘] 猎头职位-Senior system design engineer & (Senior) MCU desig
发表于 2013-9-23 17:53:08 | 显示全部楼层 |阅读模式
猎头职位-Senior system design engineer  & (Senior) MCU design and verification engineer
#1 Senior system design engineer
Job description:
The candidate will be responsible for:
?    Design and integration an AXI/AHB based system including host processor, DDR controller, SD/MMC, Display I/F and other peripherals., as a verification/demo platform for the in-house designed video IP’s;
?    Build up the simulation based environment for the system, for the functional verification;
?    Investigate and develop related drivers for the used IP’s in the system;
?    Use ISE/Vivado/Quart, implement the design to Altera/Xilinx FPGAs,
?    Work with SW engineer, to bring up system/OS on the FPGA prototyping board. Debug and resolve failures with Logic Analyzer and/or ChipScope/SignalTap;
Qualification:
?    BS with 5+ years or MS with 2+ years experiences in electronic engineering/micro-electronics;
?    Must be highly self-motivator and good team player;
?    Good understanding and hands-on experiences in SOC development and related methodology;
?    Solid skills in logic design with Verilog/VHDL, timing closure and analysis;
?    Familiar with FPGA implementation with ISE/Quartus and debugging;
?    Knowledge and hands-on experiences in at least 2 of the below fields are required;
?    AXI/AHB bus protocols;
?    Design or bring-up of DDR2/3 controller/PHY;
?    Display interfaces/protocols such as LVDS/HDMI;
?    SD/MMC controller;
?    NAND/NOR flush controller;
#2. CPU Verification Intern
Job description:
The candidate will take part in verification for the in-house designed CPU/MCU, including:
?    Maintain and improve the verification environment and flow;
?    Make the test plan according to the design specification, and execute it with System verilog based coverage monitors/assertions;
?    Develop direct tests and constraint random tests;
?    Coverage data collection and analysis;
Qualification:
?    Graduate student who will graduate in 2015, major in electronic engineering/micro-electronics;
?    Must be highly self-motivated, eager to learn and accept new knowledge, a quick learner;
?    Could work at least 4 days every week;
?    Knowledge and understanding of computer architecture and micro-architecture of RISC processors
?    Familiar with front-end ASIC design flow and Verilog HDL;
?    Familiar or experiences in high-level verification methodology (VMM/UVM/OVM), and/or hardware verification language (SystemC/SystemVerilog) would be a great plus;
?    Experiences or skills in assembly programming, and using scripting languages (Perl/Tcl/Shell) for flow automation is a plus;
#3. (Senior) MCU design and verification engineer
Job description:
The candidate will be responsible for in-house micro-controller design and verfication, including:
?    Micro-architecture definition;
?    Logic implementation with Verilog HDL;
?    Functional verification and performance tuning;
?    Synthesis and timing closure;
Qualification:
?    Solid skills and rich experiences in logic design, synthesis and timing analysis;
?    Familiar with all front-end flows including LINT check, simulation, synthesis, STA, formal and power analysis, etc.;
?    Knowledge and experiences in Computer Architecture and RISC processor (ARM/MIPS/SPARC) micro-architecture, familiar with associated tool-chains such as compiler, assembler, debugger etc.;
?    Familiar with CABAC algorithm in video coding standard such like H.264/AVC and HEVC or hands-on engineering experiences in video codec development is a big plus;
E-Mail: bestgrace@qq.com
QQ: 2043753191
新浪blog:
http://blog.sina.com.cn/u/1767088102
新浪微博:
http://weibo.com/bestgrace
GMT+8, 2025-12-24 02:45 , Processed in 0.014527 second(s), 3 queries , Gzip On, Redis On.
