楼主: maxi2010
New patch for 2013-year cadence soft: IC616 etc
发表于 2015-6-24 14:09:14 | 显示全部楼层
that is very good. thanks for your share
发表于 2015-6-24 16:35:46 | 显示全部楼层
gooood
发表于 2015-6-30 15:14:56 | 显示全部楼层
能用,但是发现ahdl编译时不同了,好像是patch坏了
发表于 2015-7-18 16:11:39 | 显示全部楼层
Thanks
发表于 2015-7-27 06:58:01 | 显示全部楼层
Thanks!!!
发表于 2015-8-8 02:16:53 | 显示全部楼层
dfgdfgdfdsfsdfsdfs
发表于 2015-8-20 17:41:21 | 显示全部楼层
good job
发表于 2015-8-23 18:32:11 | 显示全部楼层
Hi.
This patch causes Cadence Virtuoso versions  IC6.1.6-64b.500.12 and  IC6.1.6-64b.500.13 to crash at the start-up.
Can the patch be fixed?
发表于 2015-8-29 22:27:25 | 显示全部楼层
76% ../IC616/tools.lnx86/lib/6error: failed to read+write: ../IC616/tools.lnx86/lib/64bit/SuSE/SLES11/libexpat.so.0 - skipping
error: failed to read+write: ../IC616/tools.lnx86/lib/64bit/SuSE/libexpat.so.0 - skipping
85461 files checked, 0 changed.
2 errors occurred.
发表于 2015-8-29 22:29:50 | 显示全部楼层
2 errors occurred.
请问这是为啥呢?还有IC616不能输入字符。
GMT+8, 2025-11-25 12:41 , Processed in 0.019630 second(s), 4 queries , Gzip On, Redis On.
