查看: 9025|回复: 21
Cadence16.6 及最新Hotfix 015高速下载
发表于 2013-8-27 11:22:40 | 显示全部楼层 |阅读模式
Cadence SPB16.6下载(Hotfix015已发布)
Cadence SPB16.6已经推出,需要的朋友可以点击下面的链接下载:
http://dl.vmall.com/c0a86scubw
DATE: 08-22-2013HOTFIX VERSION: 015
CCRIDPRODUCTPRODUCTLEVEL2 TITLE
1156102 PCB_LIBRARIAN CORE PDV severeperformance degradation on Linux platform makes PDV counter productive aftersome time
1165756 CONCEPT_HDL CORE DE HDL 16.6adding ASCII character to properties
1169896 ADW LRMLibrary RevisionManager makes updates but the interface never returns to the user
1170635 SIP_LAYOUTWIZARDSBGA PIN NAMEdoesn't sync with PIN Number
1171061 ALLEGRO_EDITOR PLACEMENTPlace Replicate Apply cannot placemodule
1171415 CONCEPT_HDL CORE Mismatch in theinterface ports in design bw_hybrid for block a38410_scsp
1171598 APD WIREBOND Cannot load xmlover 65 profiles defined in file.
1171713 ADW LRMBlank linesappear in the LRM - RM-Clicking causes LRM to crash
1172576 SIP_LAYOUTIMPORT_DATAAIF import failswith Error: symbol is missing refdes
1172938 ALLEGRO_EDITOR PLOTTING Export IPF probrem
1173190 ALLEGRO_EDITOR ARTWORKNot able to Add/ Replacefilm_setup.txt file in Artwork control file.
1173750 ALLEGRO_EDITOR REPORTSSIP tool crash when clicking report"Net Loop Report"
1175582 ALLEGRO_EDITOR SKILLaxlDBCreateFilmRec error undifinedfunction
发表于 2013-8-27 11:50:06 | 显示全部楼层
thank you ..不過沒有 使用PCB 類TOOL
发表于 2013-8-27 14:42:08 | 显示全部楼层
感谢楼主
发表于 2013-8-31 15:37:08 | 显示全部楼层
goodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgoodgood
发表于 2013-8-31 18:13:44 | 显示全部楼层
楼主真是好人
发表于 2013-9-14 09:28:54 | 显示全部楼层
回复 1# micdot
发表于 2013-9-14 09:49:33 | 显示全部楼层
will try it , thanks
发表于 2013-9-15 09:57:39 | 显示全部楼层
回复 5# pumpkin
    请问  您已经下载好cadence  16.6了吗?我不知道怎么下载,能否发我一份啊!!!谢谢了!!!1052534780@qq.com
发表于 2013-9-25 15:30:36 | 显示全部楼层
ASI可以用吗?
发表于 2013-9-30 23:10:28 | 显示全部楼层
lz,原来的破解方式是否还管用?
GMT+8, 2025-12-21 22:37 , Processed in 0.023978 second(s), 6 queries , Gzip On, Redis On.
