查看: 1542|回复: 0
[招聘] Cadence SH 招聘Lead PV Design Engineer
发表于 2013-8-23 11:45:04 | 显示全部楼层 |阅读模式
If you have interest, PLS send your CVto zhangyl@cadence.com
更多职位信息敬请关注Cadence公众微信平台:Cadence_Recruitment
Job Title:
Jobdescription:
1.
As an Encounter product validationengineer, he/she will contribute to overall Encounter quality/stability andusability, enable designs easier to finish design timing closure and chipfinishing.
2.
Need to run different designs fromplacement/cts/optimization to final SI timing closure, need to look at thosetiming degradations and analysis the reason, whether placement is not good, oroptimization insert unreasonable buffers, or routing pattern is detour, etc.Also need to analysis those max_tran/max_cap/DRC/power issues.
3.
Need to take new designs to add intoregression suite. By given library and RTL netlist, she/he need to createfloorplan, create powerplan, go through APR flow to achieve DRC clean andtiming closure, to get reasonable Performance/Power/Area metric, just liketaping out designs.
4.
Can explore new flows or methodologyto improve timing closure efficiency, and give customer support.
Position requirements:
1. Ph.D or excellent MS which isfamiliar with APR flow.
2. Good at STA. Know about place,routing, cts, optimization and SI analysis is a plus.
3. Know about RTL synthesis
4. Good at unix scripts, cshell. Perlis a plus
5. Strong ability in analysis andsolving issues, strong ability in facing difficulty and challenges. Proactivein work.
6. Good English skill, communication skill and good team work.
Job Title:Lead PV Engineer
Position Description:
1.This job is animportant addition to our R&D team to develop Cadence Encounter DigitalImplementation System (EDI)
2.Responsible fordeveloping, applying, and improving quality standard for Cadence EDI products
3.Required to acquireexpertise and ownership over existing product components as well as developbrand new product features.
4.Help identifying newtechnology challenges in advanced process nodes and proactively provide theproduct improvement suggestion to R&D
5.Build up EDIexpertise and deliver support to field team and customers whenever needed
Position Requirements:
1.CS/EE BS degree with5+ years or MS degree with 3+ years of EDA or IC design related experience.
2.Good experience withPlace and Route design flow using EDA tools. Good knowledge of LEF/DEF.
3.Be familiar with ICback-end design flow, from netlist to gdsout.
4.Stronganalysis/bedbug capability for technical issues, be detailed oriented with afocus on quality.
5.Good team playerwith strong written and verbal communication skills.
6.Be able to workunder pressure, be able to work on multiple projects at the same time.
7.Good English read,write and communication Skill.
GMT+8, 2025-12-23 22:46 , Processed in 0.015168 second(s), 6 queries , Gzip On, Redis On.
