查看: 2119|回复: 1
[招聘] Physical Design的人才们看过来呀!!!
发表于 2013-8-22 15:17:43 | 显示全部楼层 |阅读模式
上海,资深的Physical Design的亲人们看过来呀看过来~~~
QQ1247070482(请备注来自eetop论坛)
电话13661504454
小白在这等着你过来,等着你过来,看那钱花儿开!!!
Position Description:Perform physical design implementation, including synthesis, floor planning, power grid design, place and route, clock tree synthesis, timing closure, power/signal integrity signoff, physical verification (DRC/LVS/Antenna), EM/IR signoff, DFM Closure, and physical design project management.
The candidate will have the opportunity to work on many varieties of challenging designs, i.e. low power and high speed design. The responsibility includes participating in or leading next generation physical design, methodology and flow development.
Position Requirements:BS degree with 5~10+ years of applicable experience, MS degree with 4~7+ years of applicable experience in electrical engineering, microelectronics. Experienced with ASIC design flow, hierarchical physical design strategies, and methodologies and understand deep sub-micron technology issues. Solid knowledge on LP Design, DFT, static timing analysis, EM/IR-Drop/crosstalk analysis, formal verification, physical verification, DFM. Successful track records of taping out complex, 65/40/28 nm SOC chips. Automation and programming-minded, solid coding experience in Makefile/Tcl/Tk/Perl. Self-motivated, able to work independently or as a team player, excellent verbal and written communication skills in English.
 楼主| 发表于 2013-8-23 13:12:01 | 显示全部楼层
快来啊
GMT+8, 2025-12-23 20:41 , Processed in 0.018409 second(s), 5 queries , Gzip On, Redis On.
