查看: 1664|回复: 1
[招聘] 上海外资固态照明 SSL or SMPS 架构师招聘
发表于 2013-8-15 16:03:45 | 显示全部楼层 |阅读模式
Lighting System Architect
要求有SSL或者SMPS产品经验工作8年以上
感兴趣的同学可与我联系( mail : 192431083@qq.comQQ:192431083)
Responsibilities:
* Responsible for Solid State Lighting Driver IC and Solid State LightingApplication architectures.
* Responsible for the Application Specification and the IC FunctionalRequirement Specification.
* Generating overall system requirements based on market needs balanced againstcost and timing
* Interface with the design and application engineers so that any problemsarising during design or implementation can be resolved in accordance with thefundamental design concepts, user needs and constraints (e.g. cost, timing).
* Define architectures for high yield volume manufacturing and IP reuse.
* Generate a set of acceptance test requirements together with applicationengineers, IC designers test engineers and customer which determine that all ofthe key system specifications have been met.
* Define technical direction for market leadership
* Own technical overview of segment, including competitive landscape,benchmarking, trends
* Provide technical support to marketing, identify key value drivers
* Define products, through system simulation & prototyping, FRS,architecture
* Coach Design staff, guard implementation, build and maintain IP
* Drive knowledge exchange, write ID submissions, be leading in own field
* Participate in CCBs, actively follow all PR/CRs. Resolve system issues
Your Profile:
* MSc. (Electrical Engineering) or similar
* Minimum 8 years working experience. Proven experience in drivers for SSL orSMPS products
* Ability to break down the overall application into manageable subsystems andspecify these subsystems to allow efficient IC implementation.
* Understanding of mixed-signal design and firmware.
* High degree of autonomy and strong teamwork and motivation abilities
* Ability to perform a system cost-benefit analysis linking product cost &performance to overall application cost & performance and thus tocompetitiveness
* Entrepreneurial drive, result driven and challenge-oriented (capability toselect, focus on key product targets and to build momentum with counterparts)
* Strong interpersonal skills in international environment with strong customerfocus
 楼主| 发表于 2013-8-22 10:56:43 | 显示全部楼层
GMT+8, 2025-11-6 14:22 , Processed in 0.019241 second(s), 7 queries , Gzip On, Redis On.
