查看: 2263|回复: 0
[招聘] [招聘]Cadence北京招微电子/EE背景软件测试工程师
发表于 2013-8-13 18:16:39 | 显示全部楼层 |阅读模式
Lead PV Engineer - Characterization RD
Position Description:
The positions are for a PV who will be responsible for designing, implementing, and maintaining library characterization and validation software for use with standard cells, memory and macro blocks, and IO cells.
Requirements:
The candidates should have experiences in EDA software.
Must be proficient in C, C++, TCL, Perl and development in Linux/Unix.
Knowledge on semiconductor device is strong plus.
Experience with SPICE or SPICE-like circuit simulation is important.
Knowledge of Verilog and VHDL is also highly desirable.
The ideal candidate would have a good understanding of library characterization, IP design, static timing analysis, power analysis, and signal integrity analysis flows.
Minimum Education Required / Minimum Experience Required : Master or Ph.D. in MS, EE,CS, Math or Physics
请将简历投递至cecilyl@cadence.com
GMT+8, 2025-12-23 20:41 , Processed in 0.186166 second(s), 4 queries , Gzip On, Redis On.
