查看: 2592|回复: 2
[求助] ADC采保电路
发表于 2013-8-8 17:54:43 | 显示全部楼层 |阅读模式
为什么加了开关电容共模反馈(采保电路运放的),SFDR从97dB,掉到76dB。。97dB是理想的共模反馈情况下的。
发表于 2013-9-4 17:47:12 | 显示全部楼层
look into tran simulation range to opamp swings, if it is swings from common mode which i want to set or not.
发表于 2014-6-28 16:53:43 | 显示全部楼层
check op bias !
GMT+8, 2025-12-18 14:52 , Processed in 0.028718 second(s), 5 queries , Gzip On, Redis On.
