查看: 13597|回复: 55
[招聘] AMD(上海)SOC Team急招
发表于 2013-7-23 18:03:21 | 显示全部楼层 |阅读模式
AMD(上海) SOC Team近期有数个JuniorSeniorStaff以及更高level的职位空缺招聘,感兴趣的同学可与我联系( mail : amd_cdc@163.com QQ:1756384832)team内部推荐成功率会更高些哦。
职位:
1.SOC Integration Engineer : 主要涉及Synthesis/STA/LEC/MVRC/CDC/GCA等,要求一定的脚本能力(perl,shell,tcl...)。如果对上述一个或多个领域熟悉并且感兴趣的同学可以来尝试下。
2.SOC DV Engineer : 主要涉及SOC chip levelverification已经Emulation
具体JD
aSOC Integration Engineer
Integrate GPU blocks as chip based on architectural requirement.
Develop RTL code for macro blocks in Verilog HDL and make sure functional correct and reusable for different configuration.
Synthesis and deliver netlist that meeting timing, area and power requirement. Help PD on the floorplanning and close timing.
Requirement:
MS degree of EE with 2~ 8 years, or bachelor with 5~10 years working experience in ASIC Company.
Familiar with Verilog RTL design and has experience of large digital ASIC project.
Familiar with front-end EDA tools and flows (Design compiler, PrimeTime, Conformal,Verdi, 0in)
Familiar with unix/linux and scripts (tcl, perl etc.)
Fluent English on talking, presentation and writing documents.
Strong sense of task scheduling and deliver on time as predetermined milestones committed to manager.
b)SOC DV Engineer:
The candidate will be employed in dGPU SoC level verification.
Key Job Functions:
- Understand the architecture and functionality of the chip
- Compose test plan and validation vectors to ensure functional completeness
- Develop verification environments for standalone unit testing and enhance/usethe automated regression infrastructure setup for full chip functionalverification.
- Help debug and correct functional errors in the design blocks, using logicabstraction, simulation and debug tools, based on good understanding of thearchitectural
specification, RTL and/ordevice level design of the block.
- Be responsible to mentor and coach the team for greater technical depth inFunctional areas as well as the verification methodology improvement and Infrastructureenhancements to support the design environment
Preferred Experience:
- Major in EE, CS or related with 2+ years working experiences
- Should be versatile in any one of the high level verification flow such asSV,VMM,VERA,OVM etc as well as knowledge of industry standard tools forverification
- Needs to have better understanding of Verification methodology and concepts.
- Should have good understanding of Pre-Silicon design process fromArchitecture, Design, Synthesis and Gate level Implementation till Tapeoutrelease.
- Should have excellent communication skills (both written and oral) and shouldbe able to participate cross functional engineering teams geographically.
- Familiar with Linux Environment (including shell scripting and linux gnutools)
- Proficient programming knowledge on Verilog,C++
- Knowledge on UPF based verification is a plus
- Design for verification (assertion based design strategies, code coverage,functional coverage, test plan, gate-level simulation, back-annotation etc.)
- Strong problem solving skills
 楼主| 发表于 2013-7-23 18:16:06 | 显示全部楼层
有同学已经安排面试咯
 楼主| 发表于 2013-7-24 10:56:04 | 显示全部楼层
已经陆续开始面试和录取了,名额有限,有意向的同学们速速哦。
 楼主| 发表于 2013-7-26 12:17:29 | 显示全部楼层
机会很多啊
 楼主| 发表于 2013-7-26 12:35:03 | 显示全部楼层
也非常欢迎有CAD经验的同学哦
 楼主| 发表于 2013-7-26 18:49:36 | 显示全部楼层
Up
 楼主| 发表于 2013-7-27 11:12:05 | 显示全部楼层
面试如上海的天气一样,热~
期待有意向的同学踊跃哦。
 楼主| 发表于 2013-7-28 13:03:47 | 显示全部楼层
Up Up Up
 楼主| 发表于 2013-7-28 13:50:27 | 显示全部楼层
非常欢迎有CAD经验的同学加入哦
 楼主| 发表于 2013-7-30 11:43:56 | 显示全部楼层
UpUpUp
GMT+8, 2025-12-29 07:20 , Processed in 0.020916 second(s), 6 queries , Gzip On, Redis On.
