查看: 2770|回复: 7
[招聘] AMD(上海)SOC Team急招
发表于 2013-7-20 16:27:13 | 显示全部楼层 |阅读模式
AMD(上海) SOC Team近期有数个JuniorSeniorStaff以及更高level的职位空缺招聘,感兴趣的同学可与我联系( mail : amd_cdc@163.com  QQ:1756384832)team内部推荐成功率会更高些哦。
职位:
1.SOC Integration Engineer : 主要涉及Synthesis/STA/LEC/MVRC/CDC/GCA等,要求一定的脚本能力(perl,shell,tcl...)。如果对上述一个或多个领域熟悉并且感兴趣的同学可以来尝试下。
2.SOC DV Engineer : 主要涉及SOC chip levelverification已经Emulation
具体JD
a)SOC Integration Engineer:
The candidate is preferred to be MSEE or BSEE with several years experience indigital ASIC/SOC design engineering.
The candidate should have deep understanding on ASIC/SOC design flow and mustbe proficient in some following skill sets:
1. RTL(verilog) coding and style checking
2. Scripts based on makefile, perl, TCL or csh/tcsh
3. Clock-domain-cross checking
4. Logic synthesis
5. Static timing analysis
6. Logic equivalency checking
7. Top level integration, pad-ring design
b)SOC DV Engineer:
The candidate will be employed in dGPU SoC level verification.
Key Job Functions:
- Understand the architecture and functionality of the chip
- Compose test plan and validation vectors to ensure functional completeness
- Develop verification environments for standalone unit testing and enhance/usethe automated regression infrastructure setup for full chip functionalverification.
- Help debug and correct functional errors in the design blocks, using logicabstraction, simulation and debug tools, based on good understanding of thearchitectural
specification, RTL and/ordevice level design of the block.
- Be responsible to mentor and coach the team for greater technical depth inFunctional areas as well as the verification methodology improvement and Infrastructureenhancements to support the design environment
Preferred Experience:
- Major in EE, CS or related with 2+ years working experiences
- Should be versatile in any one of the high level verification flow such asSV,VMM,VERA,OVM etc as well as knowledge of industry standard tools forverification
- Needs to have better understanding of Verification methodology and concepts.
- Should have good understanding of Pre-Silicon design process fromArchitecture, Design, Synthesis and Gate level Implementation till Tapeoutrelease.
- Should have excellent communication skills (both written and oral) and shouldbe able to participate cross functional engineering teams geographically.
- Familiar with Linux Environment (including shell scripting and linux gnutools)
- Proficient programming knowledge on Verilog,C++
- Knowledge on UPF based verification is a plus
- Design for verification (assertion based design strategies, code coverage,functional coverage, test plan, gate-level simulation, back-annotation etc.)
- Strong problem solving skills
发表于 2013-7-20 22:30:12 | 显示全部楼层
有低的职位么,应届生要不
发表于 2013-7-20 23:12:42 | 显示全部楼层
顶一个呵呵
 楼主| 发表于 2013-7-21 11:47:58 | 显示全部楼层
回复 2# fl550780
    应届生只能走校招的通道哦
 楼主| 发表于 2013-7-22 22:43:51 | 显示全部楼层
Up
发表于 2013-7-24 21:34:43 | 显示全部楼层
Great position ,I want to apply for ~
 楼主| 发表于 2013-7-24 23:20:32 | 显示全部楼层
有兴趣的同学,可以把简历发来哦
 楼主| 发表于 2013-7-26 00:06:28 | 显示全部楼层
up up up
GMT+8, 2025-12-23 20:41 , Processed in 0.021791 second(s), 5 queries , Gzip On, Redis On.
