查看: 6688|回复: 5
[求助] 求助:env的run_phase没问题,到了下面agent的run_phase就跑不动了
发表于 2013-7-12 16:01:13 | 显示全部楼层 |阅读模式
各位:
      最近正在使用UVM搭建验证环境。现在遇到一个问题,就是环境跑起来之后,就卡在开始的那个时刻了。以前出现这个问题都是driver的reset函数没写好,但是这次我从test---tb---env---agent---driver这样的顺序一层一层往下debug的时候发现,到env的run_phase中加入“this.print()”的代码,能正常运行,而到了master_agent中的run_phase加入这个代码,就一直运行不了,而master_agent的其他phase中,比如build_phase和connect_phase则没问题。我觉得仿真应该是卡在这里了,但是为什么卡住?真是一头雾水。虽然严重怀疑自己是犯了低级错误,但是奈何这几天热的心浮气躁,两天都没找出问题所在。因此上来求助各位。代码如下:
  1. `ifndef VDO_HANDWAVE_MASTER_AGENT_SV
  2. `define VDO_HANDWAVE_MASTER_AGENT_SV
  3. class vdo_handwave_master_agent extends uvm_agent;
  4.     vdo_handwave_config cfg;
  5.     vdo_handwave_master_sequencer sequencer;
  6.     vdo_handwave_master_driver    driver;
  7.     `uvm_component_utils_begin(vdo_handwave_master_agent)
  8.         `uvm_field_object(cfg,UVM_DEFAULT|UVM_REFERENCE)
  9.         `uvm_field_object(sequencer,UVM_DEFAULT|UVM_REFERENCE)
  10.         `uvm_field_object(driver,UVM_DEFAULT|UVM_REFERENCE)
  11.     `uvm_component_utils_end
  12.     function new(string name,uvm_component parent);
  13.         super.new(name,parent);
  14.     endfunction : new
  15.     extern virtual function void build_phase(uvm_phase phase);
  16.     extern virtual function void connect_phase(uvm_phase phase);
  17.     extern virtual task run_phase(uvm_phase phase);
  18.     extern virtual function void update_config(input vdo_handwave_config cfg);
  19. endclass : vdo_handwave_master_agent
  20. function void vdo_handwave_master_agent::build_phase(uvm_phase phase);
  21.     super.build_phase(phase);
  22.     if(cfg==null) begin
  23.         if(!uvm_config_db#(vdo_handwave_config)::get(this,"","cfg",cfg))
  24.             `uvm_warning("NOCONFIG","Config not set for master agent")
  25.     end
  26.     sequencer = vdo_handwave_master_sequencer::type_id::create("sequencer",this);
  27.     driver    = vdo_handwave_master_driver::type_id::create("driver",this);
  28. endfunction : build_phase
  29. function void vdo_handwave_master_agent::connect_phase(uvm_phase phase);
  30.     super.connect_phase(phase);
  31.     driver.seq_item_port.connect(sequencer.seq_item_export);
  32. endfunction : connect_phase
  33. function void vdo_handwave_master_agent::update_config(input vdo_handwave_config cfg);
  34.     sequencer.cfg=cfg;
  35.     driver.cfg=cfg;
  36. endfunction : update_config
  37. task vdo_handwave_master_agent::run_phase(uvm_phase phase);
  38.     this.print();
  39. endtask : run_phase
  40. `endif //VDO_MASTER_AGENT_SV
    复制代码
  1. `ifndef VDO_HANDWAVE_ENV_SV
  2. `define VDO_HANDWAVE_ENV_SV
  3. class vdo_handwave_env extends uvm_env;
  5.     vdo_handwave_master_agent master;
  6.     vdo_handwave_slave_agent  slaves[];
  7.     `uvm_component_utils_begin(vdo_handwave_env)
  8.         `uvm_field_object(cfg,UVM_DEFAULT)
  9.     `uvm_component_utils_end
  10.     function new (string name , uvm_component parent);
  11.         super.new(name,parent);
  12.     endfunction : new
  13.     extern virtual function void build_phase(uvm_phase phase);
  14.     extern virtual function void connect_phase(uvm_phase phase);
  15.     extern virtual function void start_of_simulation_phase(uvm_phase phase);
  16.     extern virtual function void update_config(vdo_handwave_config cfg);
  18.     //extern virtual task update_vif_enables();
  19. endclass : vdo_handwave_env
  20. function void vdo_handwave_env::build_phase(uvm_phase phase);
  23.         if(!uvm_config_db#(vdo_handwave_config)::get(this,"","cfg",cfg)) begin
  24.             `uvm_info("NOCONFIG","Using default_vdo_handwave_config",UVM_MEDIUM)
  25.             $cast(cfg,factory.create_object_by_name("default_vdo_handwave_config","cfg"));
  26.         end
  27.     end
  28.     uvm_config_object::set(this,"*","cfg",cfg);
  29.     foreach(cfg.slave_configs[i]) begin
  30.         string sname;
  31.         sname=$psprintf("slave[%0d]*",i);
  32.         uvm_config_object::set(this,sname,"cfg",cfg.slave_configs[i]);
  33.         master=vdo_handwave_master_agent::type_id::create(cfg.master_config.name,this);
  34.         slaves=new[cfg.slave_configs.size()];
  35.         for(int i=0;i<cfg.slave_configs.size();i++) begin
  36.             slaves[i]=vdo_handwave_slave_agent::type_id::create($psprintf("slave[%0d]",i),this);
  37.         end
  38.     end
  39. endfunction : build_phase
  40. function void vdo_handwave_env::connect_phase(uvm_phase phase);
  41.     super.connect_phase(phase);
  42. endfunction : connect_phase
  43. function void vdo_handwave_env::start_of_simulation_phase(uvm_phase phase);
  44.     set_report_id_action_hier("CFGOVR",UVM_DISPLAY);
  45.     set_report_id_action_hier("CFGSET",UVM_DISPLAY);
  46.     check_config_usage();
  47. endfunction : start_of_simulation_phase
  48. function void vdo_handwave_env::update_config(vdo_handwave_config cfg);
  49.     master.update_config(cfg);
  50.     foreach(slaves[i])
  51.         slaves[i].update_config(cfg.slave_configs[i]);
  52. endfunction : update_config
  53. task vdo_handwave_env::run_phase(uvm_phase phase);
  54. endtask : run_phase
  55. `endif //VDO_HANDWAVE_ENV_SV
    复制代码
发表于 2013-7-13 23:25:30 | 显示全部楼层
初来乍到,发表一下拙见
我怀疑您在run_phase的0时刻出现了死循环,请你查看一下自己的code。
发表于 2014-7-20 16:54:04 | 显示全部楼层
你好,我也遇到这种问题了。你是怎么解决的?
发表于 2014-7-20 17:01:03 | 显示全部楼层
和questa的uvm例子比对了一下,文件层次和内容写法一样,就是在仿真的过程中,调用了sequence 的start方法,就卡死了。搞了好几天了。头大啊。。。。。。。
发表于 2014-7-21 17:01:05 | 显示全部楼层
monitor中是不是没有做时序的事情。
发表于 2014-7-21 17:01:48 | 显示全部楼层
我的问题这样解决了
GMT+8, 2025-12-18 07:57 , Processed in 0.019054 second(s), 5 queries , Gzip On, Redis On.
