查看: 3477|回复: 0
[招聘] 3个IC职位,分别是两家公司的,大家加油。简历发HR@hi-talent.net
发表于 2013-7-9 13:08:59 | 显示全部楼层 |阅读模式
urgent position to be fulfilled is a ASIC design verification engineer. It needs experiences in CPU design. The JD is as below.
(Sr.) ASIC Design Verification Engineer
Position Description:
As part of the IP design team, the candidate will be responsible for the pre-silicon verification of in-house designed micro-processor which is a built-in component for next generation video codec IP, including:
·         Build up and maintain verification environment, including development of testbench and test generators for block-level and full-chip level simulation;
·         Develop and execute functional verification test plans, include writing tests, developing behavioral checkers and coverage/code monitors; Analyze coverage gaps and devise strategies to fill coverage holes;
·         Work with designers to debug failing tests and resolve bugs;
·         Help develop and maintain flows/scripts/tools for front-end design/verification;
Qualification:
·         BS with 5+ years or MS with 2+ years experiences in electronic engineering/micro-electronics;
·         Self-motivated team player, with strong problem resolving skills;
·         Proficient and experienced in high-level verification methodology (VMM/UVM/OVM), Verilog-HDL, and hardware verification language (SystemC/SystemVerilog);
·         Familiar with video coding standard, and/or computer architecture/micro-architecture;
·         Hands-on experienced in CPU verification, including test plan and test bench development, test case development and test coverage assessment would be a great plus;
·         Experiences in assembly programming, and using scripting languages (Perl/Tcl/Bash/Csh) for flow automation;
·         Familiar with front-end ASIC design flow;
Position: Sr. ASIC Engineer
1. This candidate should have mobile/high speed interface background and should be interesting in R&D on Video related technologies.
2. IC/IP background. Be interesting in developing and improving New IP.
3. Integration experience, be able to own testchip tapeout.
4.  With at least 3-years IP/Product R&D experience.
Job Description
-       RTL coding, new logic design, simulation, synthesis.
-       Work closely with algorithm engineer to develop/debug new IP/product. Supports FPGA engineer debugging issues on FPGA system.
-       Work closely with system/SW engineer to verificate/validate new IP/product on FPGA/System platform.
-       Deliver design/verification/application documents.
Qualification and Experience
-     Very familiar with the Verilog HDL language;
-     Create the RTL architecture for the algorithm;
-     Very familiar with C and C++;
-     Familiar with FPGA tool, ModelSim, and Synplify.
-     Familiar with the flow of the IC design.
Requirements:
-    Bachelor/Master degree in electronic/computer engineering
-    Demonstrated abilities in working independently
-    Strong communication skills
Position: ASIC Engineer of SOC and Video system
Requirements
1. BS or above in microelectronics, electrical engineering or equivalence
2. 3~5 year experience of ASIC EDA tool and front-end design/coding. Video chip experience is preferred.
3. Must have one of following EDA tool experience
a) STA, low power, DFT, synthesis
4. Must have one of following design/coding experience, video related is preferred
a) IP level micro-architecture definition, RTL design, co-work with verification owner
5. Nice to have experience of chip level clock/reset structure definition, low power partition definition
6. Good team work and communication skill (both in Chinese and English).
Responsibility
The candidate will be working on one of following items
1. SOC architecture definition and coordination including clock/reset structure definition, low power partition definition, etc.
2. Full chip timing closure, work closely with backend for tape out sign off
3. Define UPF/CPF, verify low power structure base on RTL or NETLIST level
4. Understand DFT/synthesis flow, provide necessary support
5. Video or processor related IP level micro-architecture definition, RTL design, co-work with verification owner
简历发HR@hi-talent.net
贵司有招聘需求的,欢迎和我联系;
如果你和你朋友有需要看工作机会的,发简历给我HR@Hi-Talent.net
Best Regards,
Apple
Principal Consultant & General Manager @ Hi-Talent Consulting Co.,Ltd.
上海芯相会企业管理咨询有限公司
Mob:        15921265928
Skype:      ScarlettJaneJin
E-Mail:      Jane-Jin@Hi-Talent.net
QQ:         983144394
Blog:        http://blog.sina.com.cn/u/1716864892
Weibo:      http://weibo.com/u/1716864892
Linkedin:    jj_seu@hotmail.com
GMT+8, 2025-12-23 22:46 , Processed in 0.010960 second(s), 3 queries , Gzip On, Redis On.
