查看: 5763|回复: 9
calibre 2011 安装问题
发表于 2013-7-7 08:33:49 | 显示全部楼层 |阅读模式
/home/woyun/mentor/x86_cal_2011.2_34.26/bin/calibre: line 214: basename: command  not found
WARNING: $CALIBRE_HOME and $MGC_HOME are different, using $CALIBRE_HOME=/home/wo yun/mentor/x86_cal_2011.2_34.26
/home/woyun/mentor/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 75: basename: command not found
/home/woyun/mentor/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 131: tr: command not found
/home/woyun/mentor/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 147: /usr/bin/: is a directory
/home/woyun/mentor/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 148: /usr/bin/: is a directory
/home/woyun/mentor/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 149: /usr/bin/: is a directory
/home/woyun/mentor/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 150: /usr/bin/: is a directory
ERROR: Unknown system type:
这个怎么解??  谢谢
发表于 2013-7-8 12:08:59 | 显示全部楼层
It seems like there is a conflict between variable CALIBRE_HOME and MGC_HOME. For me, I set only CALIBRE_HOME and it works well.
发表于 2013-7-8 12:27:07 | 显示全部楼层
My previous post is incorrect. Calibre script can manage these 2 variables by itself. The problem would be that your system didn't have programs "basename" and "tr", so check your linux distro how to install those packages and this should do the trick.
 楼主| 发表于 2013-7-9 13:21:18 | 显示全部楼层
already solved  thanks anyway
发表于 2013-11-22 13:46:53 | 显示全部楼层
I suffered the same problem, how you solved the problem?Please tell me how to do, thanks very much.
发表于 2013-12-15 13:45:11 | 显示全部楼层
学习下。。。
发表于 2014-1-16 22:01:15 | 显示全部楼层
学习下,还没下好呢
发表于 2014-5-18 14:24:34 | 显示全部楼层
回复 1# zhangfuquan
    我遇到同样的问题,你说如何解决的啊?谢谢了
发表于 2019-5-10 08:16:34 | 显示全部楼层
感谢分享
发表于 2020-11-27 14:04:58 | 显示全部楼层
分享下结果赛,楼主
GMT+8, 2025-12-26 11:57 , Processed in 0.024746 second(s), 6 queries , Gzip On, Redis On.
