查看: 10304|回复: 17
[求助] Error (ADE-3036)
发表于 2013-6-27 18:41:50 | 显示全部楼层 |阅读模式
ic615仿真时候。点击绿色按钮 就提示下面错误,无法运行。哪位知道这个咋回事?谢谢 啊
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
Possible cause could be an invalid command line option for the version of the simulator
you are running. Choose Setup->Environment and verify that the command line options
specified in the userCmdLineOption field are supported for the simulator.
Alternatively, run the simulator standalone using the runSimulation file in the netlist
directory to know the exact cause of the error.
发表于 2014-9-18 00:10:07 | 显示全部楼层
ADE->Environment, choose "run with 64 bit binary". It should work. First check your operating system is 32 bit or 64 bit. If it is 32 bit OS, don't use the mmsim version better than 11.
发表于 2014-11-12 20:10:49 | 显示全部楼层
楼主问题解决了吗?求解决方法~~
 楼主| 发表于 2014-11-12 20:55:26 | 显示全部楼层
时间故去很久了,记得是 bashrc 之类的配置文件没有设置正确
发表于 2015-5-27 14:27:10 | 显示全部楼层
我也遇到这个问题了,有大牛知道怎么解决吗?
发表于 2015-5-28 10:27:57 | 显示全部楼层
回复 4# spectre.rf
      楼主能回忆一下,具体哪里的设置吗?我同样问题,怎么都没办法解决。
发表于 2015-8-29 08:07:15 | 显示全部楼层
同求。。。。
发表于 2016-6-8 18:37:23 | 显示全部楼层
同求啊!
发表于 2016-10-17 21:45:32 | 显示全部楼层
求问啊,遇到同样的问题在调用ADS 进行电磁仿真的时候
发表于 2016-10-18 08:37:13 | 显示全部楼层
mmsim插件装了没有,如果装了就在.bashrc文件里改一下环境变量,让mmsim认出来,一般是这个问题
GMT+8, 2025-12-23 10:17 , Processed in 0.025528 second(s), 6 queries , Gzip On, Redis On.
