查看: 18252|回复: 19
[求助] PLL仿真求助!
发表于 2013-6-21 09:14:58 | 显示全部楼层 |阅读模式
我的PLL在服务器上做的,拷打虚拟机上,仿真就不行了,原理图没做任何修改,仿真条件也一样。出现如下问题,
Notice from spectre during IC analysis, during transient analysis `tran'.
    Gmin = 1 pS is large enough to noticeably affect the DC solution.
        dV(I7.I0.I15.net21) = -394.421 mV
        Use `gmin_check' option to eliminate or expand this report.
    Initial condition computed for node I0.net301 is in error by 1.41362 mV.
    Initial condition computed for node I0.net305 is in error by 1.41362 mV.
        To reduce error in computed initial conditions, decrease `rforce'.
        However, setting rforce too small may result in convergence
        difficulties or in the matrix becoming singular.
Important parameter values:
    start = 0 s
    outputstart = 0 s
    stop = 40 us
    step = 40 ns
    maxstep = 800 ns
    ic = all
    skipdc = no
    reltol = 1e-03
    abstol(I) = 1 pA
    abstol(V) = 1 uV
    temp = 27 C
    tnom = 27 C
    tempeffects = all
    errpreset = moderate
    method = traponly
    lteratio = 3.5
    relref = sigglobal
    cmin = 0 F
    gmin = 1 pS
    maxrsd = 0 Ohm
    mos_method = s
    mos_vres = 50 mV
Error found by spectre at time = 3.25521 ps during transient analysis `tran'.
    Signal V(I0.C5.cap.hn1) = 22.1835 GV exceeds the blowup limit for the
        quantity `V' which is (1 GV). It is likely that the circuit is
        unstable. If you really want signals this large, set the `blowup'
        parameter of this quantity to a larger value.
Analysis `tran' terminated prematurely due to error.
finalTimeOP: writing operating point information to rawfile.
Trying `homotopy = gmin'.
Trying `homotopy = source'.
Trying `homotopy = dptran'.
modelParameter: writing model parameter values to rawfile.
element: writing instance parameter values to rawfile.
outputParameter: writing output parameter values to rawfile.
designParamVals: writing netlist parameters to rawfile.
primitives: writing primitives to rawfile.
subckts: writing subcircuits to rawfile.
在-----------------------------------------------------------------------------------
在服务器上没有这些问题,求各位指教啊。
 楼主| 发表于 2013-6-21 13:11:53 | 显示全部楼层
没有人啊
发表于 2013-6-21 13:41:38 | 显示全部楼层
回复 2# yangbiwen242
你的model用对没有?
发表于 2013-6-21 18:27:09 | 显示全部楼层
spectre版本太低
发表于 2013-6-21 20:50:45 | 显示全部楼层
看看这段: Error found by spectre at time = 3.25521 ps during transient analysis `tran'. Signal V(I0.C5.cap.hn1) = 22.1835 GV,说明原理图中那个电容接到了一个理想电流源上了。
发表于 2013-6-21 21:25:40 | 显示全部楼层
电路中有理想的器件才会有这么诡异的问题吧
 楼主| 发表于 2013-6-23 10:12:08 | 显示全部楼层
回复 5# ac3m666
    没有电容直接接到理想的电流源
 楼主| 发表于 2013-6-23 10:14:58 | 显示全部楼层
回复 6# aqishisi
    确实有理想电容和电阻,但是换成工艺库里的还是出现同样的问题,而且我在服务器上仿真,没有问题(有理想电容和电阻)
发表于 2013-6-23 12:55:29 | 显示全部楼层
应该是理想电流源接到了嘛地方上
发表于 2014-3-22 19:17:32 | 显示全部楼层
回复 1# yangbiwen242
    大侠  这个问题你是咋样解决的  我也现在遇到了  晕死
GMT+8, 2025-12-3 18:41 , Processed in 0.022009 second(s), 5 queries , Gzip On, Redis On.
