楼主: ald_syn_cad
X64_Agilent SystemVue 2013.01 patch
发表于 2014-11-6 09:02:47 | 显示全部楼层
我的win 7 x64 ,安装后显示:
SystemVue UI You do not have a license to run this feature. Below is a list of products that contain this feature:
W1714(b_sv_ami_eval)
W1461(b_sv_commsarch)
W1460,W2030,W2130(b_sv_demo)
W1462(b_sv_fpgaarch)
W1460I(b_sv_internal)
W1464(b_sv_rfarch)
W1465(b_sv_sdrarch)
Possible Causes:
1. A license for the feature was not purchased.
2. The feature could not be found in the license file or on the server or is invalid.
3. You are pointing to the wrong license file or server.
4. The license file was altered.
5. The distributed simulation on the remote computer(s) does not use the same license server(s) as the local computer. Troubleshooting Tips:
1. Check the license file or server you are trying to use contains the right licenses for this product.
2. Verify that you are pointing to the correct server and license file using the wizard. 3. Verify that you do not have a license preference set to a feature that has been removed on the server.
4. Use the License Manager's Licenses tab to view your licenses and available features.
请问是什么原因 啊 ?希望能得到各位大侠的帮助,谢谢
发表于 2014-11-6 20:28:43 | 显示全部楼层
it does not work
发表于 2014-11-9 13:36:29 | 显示全部楼层
回复 2# hnwulei
   感謝版主無私分享!
发表于 2014-12-5 22:11:27 | 显示全部楼层
可以用,谢谢。
发表于 2015-1-17 22:34:59 | 显示全部楼层
回复 1# ald_syn_cad
   X64_Agilent SystemVu   Gooood!
发表于 2015-4-3 22:42:07 | 显示全部楼层
t does not work
发表于 2015-5-3 20:41:34 | 显示全部楼层
利用楼主的crack在win8系统上成功激活SystemVue 2013.08 x64,
mark下 谢谢
发表于 2015-5-11 04:56:05 | 显示全部楼层
very bad crap
发表于 2015-9-25 10:19:36 | 显示全部楼层
let me check
发表于 2015-10-27 09:49:51 | 显示全部楼层
thanks a lot for this info, will try, can i use it for latest ADS?
GMT+8, 2025-12-25 21:16 , Processed in 0.018766 second(s), 5 queries , Gzip On, Redis On.
