查看: 7555|回复: 29
ERadio_Frequency_Circuit_Design_-_Alan_Davis__Krishna_Agarwal
发表于 2007-1-19 11:46:42 | 显示全部楼层 |阅读模式
啥也不说了,眼泪哗哗的!
Radio_Frequency_Circuit_Design_-_Alan_Davis__Krishna_Agarwal.rar
3.71 MB, 下载次数: 204 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-1-31 09:02:59 | 显示全部楼层
这么好的书没人顶的啊,是做RF的都要的啊
书名错了:Radio_Frequency_Circuit_Design_-_Alan_Davis__Krishna_Agarwal
The cellular telephone has become a symbol for the rapid change in the communications
business. Within this plastic container reside the talents of engineers
working in the areas of efficient power supplies, digital circuit design, analog
circuit design, semiconductor device design, antennas, linear systems, digital
signal processing, packaging, and materials science. All these talents are carefully
coordinated at a cost that allows a wide cross section of the world’s population to
have available instant communication. The particular aspect of all these activities
that is of primary focus in this text is in the area of analog circuit design, with
primary emphasis on radio frequency electronics. Some topics normally considered
in electronics courses or in microwave and antenna courses are not covered
here. For example, there is no mention of distributed branch line couplers, since
at 1 GHz their size would be prohibitive. On the other hand, topics such as transmission
line transformers are covered because they fit so well into this frequency
range.
This book is meant for readers who have at least advanced standing in electrical
engineering. The material in this text has been taught as a senior and
graduate-level course in radio frequency circuit design at the University of Texas
at Arlington. This class has continued to be popular for the past 20 years under
the guidance of at least four different instructors, two of whom are the present
authors. Because of the activity in the communications area, there has been ever
greater interest in this subject. It is the intent of the authors, therefore, to update
the current text offerings while at the same time avoiding simply reworking a
microwave text.
The authors gratefully acknowledge the contribution of Michael Black,
Raytheon Systems Company, to the phase lock loop discussion in Chapter 12.
W. Alan Davis
Krishna Agarwal
发表于 2007-1-31 13:02:24 | 显示全部楼层
我支持!
发表于 2007-1-31 13:08:59 | 显示全部楼层
Copyright  2001 by John Wiley & Sons, Inc. All rights reserved.
发表于 2007-1-31 13:11:42 | 显示全部楼层
232页的EBook,
Contents
Preface xiii
1 Communication Channel 1
1.1 Basic Transmitter–Receiver Configuration 1
1.2 Information and Capacity 3
1.3 Dependent States 6
Problems 8
References 8
2 Resistors, Capacitors, and Inductors 9
2.1 Introduction 9
2.2 Resistors 9
2.3 Capacitors 14
2.4 Inductors 20
Problems 31
References 31
3 Impedance Matching 33
3.1 Introduction 33
3.2 The Q Factor 33
3.3 Resonance and Bandwidth 34
3.4 Unloaded Q 36
3.5 L Circuit Impedance Matching 36
3.6  Transformation Circuit 39
3.7 T Transformation Circuit 41
3.8 Tapped Capacitor Transformer 42
3.9 Parallel Double-Tuned Transformer 45
Problems 49
References 50
发表于 2007-1-31 13:12:32 | 显示全部楼层
content
4 Multiport Circuit Parameters and Transmission Lines 51
4.1 Voltage–Current Two-Port Parameters 51
4.2 ABCD Parameters 53
4.3 Image Impedance 54
4.4 The Telegrapher’s Equations 59
4.5 The Transmission Line Equation 61
4.6 The Smith Chart 63
4.7 Commonly Used Transmission Lines 65
4.8 Scattering Parameters 74
4.9 The Indefinite Admittance Matrix 78
4.10 The Indefinite Scattering Matrix 80
Problems 82
References 82
5 Filter Design and Approximation 84
5.1 Introduction 84
5.2 Ideal and Approximate Filter Types 84
5.3 Transfer Function and Basic Filter Concepts 88
5.4 Ladder Network Filters 89
5.5 The Elliptic Filter 94
5.6 Matching between Unequal Resistances 95
Problems 104
References 104
6 Transmission Line Transformers 105
6.1 Introduction 105
6.2 Ideal Transmission Line Transformers 106
6.3 Transmission Line Transformer Synthesis 110
6.4 Electrically Long Transmission Line Transformers 111
6.5 Baluns 115
6.6 Dividers And Combiners 117
Problems 121
References 121
7 Class A Amplifiers 122
7.1 Introduction 122
7.2 Definition of Gain [2] 122
7.3 Transducer Power Gain of a Two-Port 123
7.4 Power Gain Using S Parameters 124
7.5 Simultaneous Match for Maximum Power Gain 127
7.6 Stability 129
7.7 Class A Power Amplifiers 139
发表于 2007-1-31 13:13:53 | 显示全部楼层
content
7.8 Power Combining of Power Amplifiers 141
Problems 142
References 143
8 Noise 144
8.1 Sources of Noise 144
8.2 Thermal Noise 145
8.3 Shot Noise 148
8.4 Noise Circuit Analysis 149
8.5 Amplifier Noise Characterization 151
8.6 Noise Measurement 152
8.7 Noisy Two-Ports 153
8.8 Two-Port Noise Figure Derivation 154
8.9 The Fukui Noise Model for Transistors 158
8.10 Properties of Cascaded Amplifiers 161
8.11 Amplifier Design for Optimum Gain and Noise 164
Problems 166
References 166
9 RF Power Amplifiers 168
9.1 Transistor Configurations 168
9.2 The Class B Amplifier 169
9.3 The Class C Amplifier 178
9.4 Class C Input Bias Voltage 183
9.5 The Class D Power Amplifier 184
9.6 The Class F Power Amplifier 185
9.7 Feed-Forward Amplifiers 191
Problems 193
References 193
10 Oscillators and Harmonic Generators 195
10.1 Oscillator Fundamentals 195
10.2 Feedback Theory 197
10.3 Two-Port Oscillators with External Feedback 197
10.4 Practical Oscillator Example 202
10.5 Minimum Requirements of the Reflection Coefficient 204
10.6 Common Gate (Base) Oscillators 206
10.7 Stability of an Oscillator 210
10.8 Injection-Locked Oscillators 214
10.9 Harmonic Generators 216
Problems 221
References 221
发表于 2007-1-31 13:16:04 | 显示全部楼层
content(完)
11 RF Mixers 222
11.1 Nonlinear Device Characteristics 222
11.2 Figures of Merit for Mixers 226
11.3 Single-Ended Mixers 227
11.4 Single-Balanced Mixers 228
11.5 Double-Balanced Mixers 230
11.6 Double-Balanced Transistor Mixers 235
11.7 Spurious Response 240
11.8 Single-Sideband Noise Figure and Noise Temperature 243
Problems 246
References 246
12 Phase Lock Loops 247
12.1 Introduction 247
12.2 PLL Design Background 247
12.3 PLL Applications 248
12.4 PLL Basics 249
12.5 Loop Design Principles 250
12.6 PLL Components 251
12.7 Linear Analysis of the PLL [1] 255
12.8 Locking a Phase Lock Loop 259
12.9 Loop Types 261
12.10 Negative Feedback in a PLL 263
12.11 PLL Design Equations 264
12.12 PLL Oscillators 270
12.13 Phase Detector Types 271
12.14 Design Examples 274
Problems 277
References 277
13 Emerging Technology 278
13.1 Introduction 278
13.2 Bandwidth 280
13.3 Spectrum Conservation 280
13.4 Mobility 281
13.5 Wireless Internet Access 282
13.6 Key Technologies 283
References 284
Appendixes
A. Example of a Solenoid Design 285
B. Analytical Spiral Inductor Model 286
C. Double-Tuned Matching Circuit Example 290
D. Two-Port Parameter Conversion 292
E. Termination of a Transistor Port with a Load 296
F. Transistor and Amplifier Formulas 300
G. Transformed Frequency Domain Measurements
Using Spice 305
H. Single-Tone Intermodulation Distortion
Suppression for Double-Balanced Mixers 319
Index 323
发表于 2007-2-1 13:43:40 | 显示全部楼层
我支持!!!!
发表于 2007-2-1 14:08:00 | 显示全部楼层
支持楼主,辛苦了
GMT+8, 2025-12-22 00:47 , Processed in 0.021454 second(s), 4 queries , Gzip On, Redis On.
