楼主: c_j_hero
Redhat和Centos下安装全套silvaco2012软件
发表于 2014-5-29 07:53:35 | 显示全部楼层
回复 1# c_j_hero
    楼主您好,现在官网下不到linux2012版了,能给我发一个不?谢谢!liumeng35@163.com
发表于 2014-5-30 17:08:06 | 显示全部楼层
回复 64# candidater
我也是碰到这个问题,不过终于解决了。
http://hi.baidu.com/tso_c/item/47c0e1ec444585256cabb864
需要装yum install libstdc++.so.5
以及yum install compat-libstdc++*
发表于 2014-6-4 11:05:18 | 显示全部楼层
回复 1# c_j_hero
    楼主好,我的输入showid后报错:
home/sdu611/APP/silvaco2012/lib/showid/8.0.12.R/x86_64-linux/showid.exe: error while loading shared libraries: /home/sdu611/APP/silvaco2012/lib/support/i386-linux/libstdc++.so.5: file too short
是怎么回事啊,请指导,谢谢!
发表于 2014-6-4 22:36:45 | 显示全部楼层
用一下试一试,正在进行中
发表于 2014-6-11 09:29:58 | 显示全部楼层
参看以下
发表于 2014-6-23 17:51:54 | 显示全部楼层
回复 97# scsfvslahm
    你最后是怎么装上的?我也遇到同样的问题啊
发表于 2014-6-26 17:00:26 | 显示全部楼层
回复 106# lnghng
我的问题很可能是用网络代理的原因,因为我关了代理后,就可以输入密码了~
发表于 2014-7-8 01:12:33 | 显示全部楼层
跟大家一样,也是报一堆错误,安装了几个yum之类的,现在不报错了,但是还是运行不下去。出现:
rpcinfo: JUSTIN: Name or service not known
Verification failed for sflm on host JUSTIN.
详细如下:
[root@JUSTIN x86_64-linux]# sflm -i
Version of rpc.sflmserverd : 8.2.7.R
Version of sflm_monitord : 7.4.15.R
Setting SFLM administrative password.
New Password    ?
aksusbd version   1.14 (#7528) - key API (USB) version: 3.88
aksusbd version         - (parallel driver not available)
Running s_install version: 2.0.3.R  please wait...
Terminating SFLM RPC servers ... done.
Currently 14165292 KB free in /tmp (>= 8000)
Preparing to install the SFLM server daemon.
This procedure will modify or create the following system files:
        /etc/rc.d/init.d/sflm
Backups will be created in /var/tmp/s_install.bak
before any files are modified.
Run '/usr/silvaco/etc/s_install -rm-bak' or
'/var/tmp/s_install.bak/remove' to remove backup files.
Do you wish to proceed? [y|n] y
Verifying permissions ... done.
Installing servers in init.d ...
Backing up /etc/rc.d/init.d/sflm to /var/tmp/s_install.bak/bak.sflm~1~ ... done.
Installation done.
Starting and verifying servers ...
SFLM using license file: /var/opt/sflm/licenses
SFLM server ready.
RPC server verification failed.
发表于 2014-7-8 08:11:26 | 显示全部楼层
不好意思,可以了。
如果出现上面的情况,不要管它,继续按照楼主的流程走,可以安装得好!
多谢!
发表于 2014-7-18 14:40:02 | 显示全部楼层
安装好了,怎么save as用不了啊
GMT+8, 2025-12-28 22:57 , Processed in 0.019523 second(s), 5 queries , Gzip On, Redis On.
