查看: 2703|回复: 0
一级代理gm8125,gm8126,gm8128等芯片,ipcamera网络摄像机方案
发表于 2013-6-4 09:49:16 | 显示全部楼层 |阅读模式
联系人:jess   电话:13421300490  qq:906922754   email:906922754@qq.com
■ 产品简介
IP Camera是一种把图像捕捉设备(摄像机)的图像转换成IP信号进行传输的设备,一般内置摄像机和视频压缩引擎。视频数据经H264格式压缩后,通过局域网,InternetWIFI网络送至终端用户。用户可通过IE或客户端软件,进行视频的浏览访问和控制。
本方案基于升迈的GM812X系列多核SOC, (集成ARM9-CPUH264图像编解码内核)
■ 功能特点
软件开发平台化,VGA-高清开发包架构高度统一,软件一次开发多款产品。
硬件高整合度,集成网卡,ISP;外围只需挂1DDR,Flash,Senser
,大幅降低系统成本
硬件VGA 720P 1080p共板设计,应用全覆盖
图像增强技术3D-I & 3D-NR高品质的保障
低功耗,绿色环保
LQFP封装,4layer PCB设计,降低加工成本
芯片选型表:
产品分辨率
VGA
HD 720p
HD 1080p
芯片型号
GM8125
GM8126
GM8128
■ 技术参数
CPU
FA626 ARM® v5TE ISA CPU, up to 600 MHz, 32K I-cache/32K D-cache
Memory Interface
16- bit DDRII SDRAM controller up to 800MHz
SPI NOR-type flash and NAND-type flash with 24-bit ECC
H.264 Encoder
Encoder supporting baseline profile, from level 1  3.1 up to 720P@45 fps or 1080P@20 fps
MPEG-4/JPEG Encoder
MPEG-4 supporting simple profile level 0 ~ 3, encoder up to 720P@30 fps
JPEG is compliant with ISO/IEC 10918-1 baseline standard.
Video Capture
Support 2 ITU 656 interfaces - YUV 4:2:2 and 16-bit YUV interface
Resolution: Up to 1920 x 1080
Support color OSD and input fractional scalar
ISP
Support 12 bit parallel Bayer RGB
Still mode supports up to 5M (2592x1944) resolution, video mode supports
1080P@30fps
Display Interface
ITU-1120 16-bit video output, up to 1024x768
OSD with 256 programmable 12 x 16 fonts
Video DAC
Support 1 channel composite TV out
ADC
2 channels SAR ADC for battery detection, light detection or key pad
Audio Codec
Support 8 kHz ~ 96 kHz sampling rate for both ADC and DAC
90 dBFS SNR for ADC line-input and line-output
AES/DES/3DES Cipher
Hardware implementation of AES/DES/3DES algorithm with DMA function
AHB Peripherals
802.3 MAC+PHY, USB 2.0 OTG+PHY
APB Peripherals
SDIO/SDHC controller, Timer, WDT, RTC, INTC, GPIO, I²C, PMU, SPI(I²S), UART, PWM
Operating Voltage
1.0 V, 1.8 V,and 3.3 V
Package
256 TFBGA (17 x 17 mm² )
176 LQFP(20 x 20 mm² )
■ 图解
1
1
GMT+8, 2025-12-14 11:42 , Processed in 0.017198 second(s), 8 queries , Gzip On, Redis On.
