查看: 1652|回复: 0
[招聘] Cadence 北京R&D职位
发表于 2013-6-3 16:53:53 | 显示全部楼层 |阅读模式
Cadence  北京R&D职位
CadenceNasdaq: CDNS是全球领先的EDA (Electronic Design Automation)
软件开发商以及电子设计自动化解决方案提供商.我们的产品涵盖了电子设计的整个流程,包括系统级设计,功能验证,IC综合及布局布线,模拟、混合信号及射频IC设计,全定制集成电路设计,IC物理验证,PCB设计和硬件仿真建模等。全球知名半导体与电子系统公司均将Cadence软件作为其全球设计的标准。公司网站www.cadence.com.cn
If you have interest, PLS send your CV to job_china@cadence.com
1. Senior/ Software Engineer (Location: BJ)
Position Description:
Thepositions are for a developer who will be responsible for designing,implementing, and maintaining library characterization and validation softwarefor use with standard cells, memory and macro blocks, and IO cells
PositionRequirements:
1.Thecandidates should have two or more years of experiences in developing EDAsoftware.
2.Must beproficient in C, C++, TCL, and development in Linux/Unix.
3.Knowledge on semiconductor device is strong plus.
4.Experience with SPICE or SPICE-like circuit simulation is important.
5.Knowledgeof Verilog and VHDL is also highly desirable.
6.Have agood understanding of library characterization, IP design, static timinganalysis, power analysis, and signal integrity analysis flows.
7.MinimumEducation Required / Minimum Experience Required : MS, EE, CS, Math or Physics2
8.PreferredEducation / Preferred Experience: Ph.D. , EE, CS, Math or Physics 3-5
2. Senior Software engineer for Virtuoso ADEXL (Location: BJ)
Custom digital and analog circuit designersmust generate and interpret large amounts of complex simulation data. VirtuosoADE XL accelerates design by enabling setup reuse, parallelizingcompute-intensive simulation, and through extensive post-processing andvisualization capabilities. We are seeking a talented software developer toimprove simulation throughput and data visualization.
Position Requirements
1.Demonstrated proficiency in C++ and generalsoftware development skills
2.BS in Computer Science or ComputerEngineering required.
3.XML, SQL, GUI (Qt specifically), anddistributed processing experience a plus.
4.Experience with Cadence Virtuoso or analogcircuit design is a plus.
3.SeniorSoftware Engineer- Virtuoso Design Environment
PositionDescription:
Custom digital and analog circuit designersmust generate and interpret large amounts of complex simulation data. VirtuosoADE accelerates design by enabling setup reuse, parallelizing and distributingcompute-intensive simulation, and through extensive post-processing andvisualization capabilities.
As an ADE programmer, you will:
* Work closely with simulation andvisualization teams in order to streamline tool flow and deliver newcapabilities.
* Implement internal algorithms, provide APIsfor other tools to integrate, and provide GUI support for the end user.
* Carefully consider data structures to handlelarge data sets.
* Demonstrate strong OO knowledge using C++.
* Write tests to validate your implementation.
- Skilled in C++ programming, familiar withdevelopment under Linux/Unix environment;
- Familiarity with GUI development, especiallyusing the Qt toolkit is a plus
- Familiarity with XML and/or SQL is a plus
- Be familiar with Analog-signal design is aplus;
- Good English communication skill bothverbally and writing;
- Good problem solving skill and team workspirit;
4.Senior PV Engineer for Fast-SPICESimulator
- Plan and developstrategy to test Fast-SPICE Simulator.
- Develop procedures,testcases, and designs to test, troubleshoot, and debug Fast-SPICE simulatorsto make sure the products are performing up to the specifications and upholdingsoftware quality standards.
- Work closely with agroup of professionals to enhance product quality.
- Develop Perl orshell scripts to automate test procedures.
5.SeniorSoftware Engineer- simulator front end
- MS/BS or abovemajored in Microelectronics, EE, or relevant.
- Customer IC designexperience.
- Teamwork and goodcommunication skills.
- Good at both writtenand spoken English.
Title:     Seniorsoftware engineer- Simulator front end
Research and design simulator front end
Strong C++ programming and familiarity with developmentunder Linux/Unix environment.
Proficiency with linux/unix tools.
Skills in one or more of script such as Python, Perl.
Familiar with build and version-control systems.
Good English communication skill both verbally and writing.
Good problem solving skill and team work spirit.
GMT+8, 2025-12-25 20:09 , Processed in 0.023246 second(s), 7 queries , Gzip On, Redis On.
