楼主: njuer
DC/DC开关电源中的斜率补偿及其他问题
发表于 2007-1-29 16:30:19 | 显示全部楼层
Determining the Ramp Slope
Mathematically, the slope of this compensating ramp must
be equal to one-half (50%) the downslope of the output
inductor as seen from the control side of the circuit. This is
proven in detail in “Modelling, Analysis and Compensating
of the Current Mode Controller,” (Unitrode publication U-97
and its references). Empirically, slightly higher values of
slope compensation (75%) can be used where the AC
component is small in comparison to the DC pedestal, typical
of a continuous converter
发表于 2007-2-9 00:35:28 | 显示全部楼层
111111111
发表于 2007-2-9 16:15:53 | 显示全部楼层
原来是Unitrode的Application Note,早就有了,楼主最好发贴的时候有一个简要说明!
发表于 2007-2-9 20:42:59 | 显示全部楼层
下来瞅瞅!
发表于 2007-2-9 23:10:43 | 显示全部楼层
521521
发表于 2007-5-19 16:40:51 | 显示全部楼层
good thank
good thank
发表于 2007-5-19 16:48:34 | 显示全部楼层
Thanks for sharing!
发表于 2007-5-20 01:42:03 | 显示全部楼层
english paper about slope compensation is better that in chinese .
slop compensation is very important in peak current mode pwm controler.
especially in ccm .
发表于 2007-5-20 01:45:06 | 显示全部楼层
semico_ljj , thanks . do you work in smp .can you make a friends.
发表于 2007-5-20 03:24:09 | 显示全部楼层
good, thx for sharing
GMT+8, 2025-12-3 22:51 , Processed in 0.017170 second(s), 3 queries , Gzip On, Redis On.
