查看: 2104|回复: 5
[资料] An Ultra-Wide-Band 0.4–10-GHz LNA
发表于 2013-4-30 18:48:21 | 显示全部楼层 |阅读模式
Abstract—A two-stage ultra-wide-band CMOS low-noise amplifier
(LNA) is presented. With the common-gate configuration employed
as the input stage, the broad-band input matching is obtained
and the noise does not rise rapidly at higher frequency.
By combining the common-gate and common-source stages, the
broad-band characteristic and small area are achieved by using
two inductors. This LNA has been fabricated in a 0.18- m CMOS
process. The measured power gain is 11.2–12.4 dB and noise figure
is 4.4–6.5 dB with 3-dB bandwidth of 0.4–10 GHz. The measured
IIP3 is 6 dBm at 6 GHz. It consumes 12mWfrom a 1.8-V supply
voltage and occupies only 0.42 mm2.
Index Terms—Common-gate configuration, ultra-wide-band
CMOS79764430.pdf
626.31 KB, 下载次数: 67 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-5-2 19:28:03 | 显示全部楼层
下来看看
发表于 2013-5-4 05:40:38 | 显示全部楼层
謝謝大大的分享唷~~~
发表于 2016-6-2 18:40:49 | 显示全部楼层
THANK YOU
发表于 2016-9-3 10:56:23 | 显示全部楼层
Thanks for sharing
发表于 2016-9-18 16:02:08 | 显示全部楼层
haoziliao
GMT+8, 2025-12-12 16:35 , Processed in 0.020495 second(s), 6 queries , Gzip On, Redis On.
