查看: 2062|回复: 0
[招聘] NO.62-LED Field Applications Engineer(Guangzhou)
发表于 2013-4-9 16:12:38 | 显示全部楼层 |阅读模式
Job Description:
This position reports to the Business Development Manager. The FAE will reside in Shunde, China with responsibility to
·         Creating innovative state of the art LED Lighting driver circuit designs to maximize efficiency and reliability.
·         Provide high voltage LED driver design support to customers that includes: paper / theoretical designs, building full customized power supplies and winding high voltage transformers
·         Provide XX direct technical support to Key LED Lighting customers defined by Field sales.
·         Update customers with latest products information and support them with LED driver demo boards along with engineering reports.
·         Support customer projects in close co-operation with other Engineering LED Lighting team WW
·         Ability to work in a dynamic WW multi-ethnical organization
·         Conduct periodical training to distributor FAE team and workshops / seminars ( In-house & Public ) for key LED Lighting customers
Requirements –
·         Should possess strong fundamentals knowledge of LED Lighting mainly drivers and its various topologies
·         Should have strong fundamental knowledge in meeting LED driver standards (PF / THD / Surge etc ) and implementation
·         Strong Knowledge and experience in AC/DC SMPS design, testing and analysis.
·         Should possess knowledge in designing magnetic components including transformers, Common Mode chokes / Inductors etc.
·         Able to debug, designs and recommend changes.
·         Strong knowledge on design / simulation tools
·         To work closely with WW LED Application and our prototype teams in the build of cutting edge solution, components and systems.
·         Able to build good working relationships with colleagues and with customers
·         Contributes effectively to Sales strategies.
·         Strong communication skill, both verbal and in writing.
·         Locate in or nearby Guangzhou, China.
Ability to obtain Chinese travel passport and valid entry visa to the U.S.A.
·         Extensive travel throughout South China including 1-2 annual FAE meetings.
·         Fluent Mandarin, Cantonese is highly desired, moderately fluent English reading, writing, and speaking
Experience -
·         Minimum of 4-6 Years of experience in Design and Development of SMPS from LED Lighting Industry
·         Should have strong working knowledge in production & process flow for pilot and proto build.
Education -
·         BSEE/MSEE with a minimum of three years of switch mode power supply design experience
·         Diploma in Electronics with Degree in Electronics or AMIE ( Electronics )
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”或扫描以上二维码即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-18 16:45 , Processed in 0.021104 second(s), 6 queries , Gzip On, Redis On.
