查看: 7542|回复: 12
Serial: Mathworks Matlab R2013a 8.01 Fixed on 01.04.2013
发表于 2013-4-7 22:18:41 | 显示全部楼层 |阅读模式
Mathworks Matlab R2013a 8.01  Fixed 01.04.2013
For English-speaking persons:
The simplest way to setup Matlab is to run "SetupSimple.exe".
At the end of setup process when you will be asked for activation - select "Cancel".
If this activation question will appear again when you start Matlab program
please activate Matlab manually according to steps 5-6 in the list below.
If simplified setup does not work for you - just execute steps 1-6 manually.
To install follow these steps:
1) run "setup.exe" (or "bin\win32\setup.exe" to install
    32-bit Matlab under 64-bit Windows)
2) choose "install manually without using the internet"
3) set the "file installation key" to be
   25716-63335-16746-06072
4) setup Matlab with required components
5) when asked to activate the product select ?ctivate manually without internet?
6) select "X:\serial\license.lic" when asked for license file
    (where "X" is drive letter with this DVD-disk at your computer)
license.rar
3.62 KB, 下载次数: 152 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-4-8 08:44:11 | 显示全部楼层
Thanks for sharing....
 楼主| 发表于 2013-4-8 09:25:13 | 显示全部楼层
发表于 2013-4-10 19:38:02 | 显示全部楼层
kankan,xiexie...
发表于 2013-4-10 22:27:19 | 显示全部楼层
thank you
发表于 2013-4-11 04:36:32 | 显示全部楼层
what about linux version...how to use
发表于 2013-4-11 10:30:38 | 显示全部楼层
very very good, thanks a lot in advance
发表于 2013-4-12 09:47:49 | 显示全部楼层
Thanks for this great info.
发表于 2013-4-13 11:02:15 | 显示全部楼层
謝謝樓主分享以及提供連結
发表于 2013-4-23 11:28:33 | 显示全部楼层
great thanks, too many fake downloads on the internet.
GMT+8, 2025-12-28 09:36 , Processed in 0.021551 second(s), 6 queries , Gzip On, Redis On.
