查看: 6017|回复: 9
[资料] Resistor-Less Design of Power-Rail ESD Clamp Circuitin Nanoscale CMOSTechnology
发表于 2013-3-30 20:39:46 | 显示全部楼层 |阅读模式
Chih-Ting Yeh, StudentMember,IEEE, andMing-Dou Ker, Fellow, IEEE
Abstract—A resistor-less power-rail electrostatic discharge
(ESD) clamp circuit realized with only thin-gate-oxide devices
and with a silicon-controlled rectifier (SCR) as the main ESD
clamp device has been proposed and verified in a 65-nm CMOS
process. By skillfully utilizing the gate leakage current to realize
the equivalent resistor in the ESD-transient detection circuit, the
RC-based ESD detection mechanism can be achieved without
using an actual resistor to significantly reduce the layout area in
I/Ocells.Fromthemeasuredresults,thenewproposedpower-rail
ESD clamp circuit with an SCR width of 45 μm can achieve 5-kV
human-body-model and 400-V machine-model ESD levels under
the ESD stress event while consuming only a standby leakage
current of 1.43 nA at room temperature under the normal circuit
operating conditionwith1-Vbias.
Index Terms—Electrostatic discharge (ESD), gate leakage,
power-rail ESDclamp circuit, silicon-controlled rectifier (SCR).
abbr_23ef299dbe4ac53230463dcda50a31a6.pdf
411.85 KB , 阅读权限: 20 , 下载次数: 77 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-12-15 15:16:59 | 显示全部楼层
下载看看。 。。谢谢楼主。。。正需要这个呢~CLAMP啊。。
发表于 2013-12-20 06:29:48 | 显示全部楼层
不错不错...
发表于 2013-12-20 06:55:08 | 显示全部楼层
thank you so much! I need it.
发表于 2014-1-19 01:47:07 | 显示全部楼层
3kyyyyyyyyyyyyyy
发表于 2015-9-29 22:01:39 | 显示全部楼层
看看先
发表于 2015-9-30 08:33:23 | 显示全部楼层
good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2015-11-17 11:00:55 | 显示全部楼层
谢谢分享
发表于 2016-10-4 09:12:50 | 显示全部楼层
強者!
发表于 2017-8-2 09:48:06 | 显示全部楼层
thanks
GMT+8, 2025-12-21 15:38 , Processed in 0.061348 second(s), 7 queries , Gzip On, Redis On.
