查看: 7622|回复: 20
[求助] Analogue Electronic Circuits and Systems
发表于 2013-2-6 15:31:41 | 显示全部楼层 |阅读模式
悬赏20资产未解决
求书Analogue Electronic Circuits and Systems
By A. Basak
University of Wales College of Cardiff
    Publisher: Cambridge University Press
    Print Publication Year:1991
    Online Publication Date:June 2012
    Online ISBN:9781139168069
    Hardback ISBN:9780521360463
    Paperback ISBN:9780521369138
    Book DOI: http://dx.doi.org/10.1017/CBO9781139168069
    Subjects: Circuits and systems
Preface xiii
1 Introduction 1
2 Transistor circuit techniques and amplifiers 4
Objectives 4
4
5
11
12
17
21
24
34
37
38
42
48
50
53
54
59
59
60
60
62
65
70
80
80
2.1
2.1.1
2.1.2
2.1.3
2.1.4
2.1.5
2.2
2.3
2.4
2.4.1
2.4.2
2.4.3
2.4.4
3
3.1
3.1.1
3.1.2
3.1.3
3.1.4
3.2
3.2.1
Linear integrated circuits
Differential amplifiers
Constant current sources
Current mirrors
Darlington connection
Level shifting circuits
Cascaded amplifier stages
Tuned amplifiers
Power amplifiers
Class A amplifiers
Class B amplifiers
Class C amplifiers
Heat sinks
Summary
Problems
Operational amplifiers
Objectives
Imperfections in operational amplifiers
Slew rate and its effect on full power bandwidth
Input offset voltage
Bias and offset currents
Frequency response effects
Applications
Instrumentation amplifiers
Downloaded from Cambridge Books Online by IP 111.187.79.143 on Wed Feb 06 07:31:01 WET 2013.
http://ebooks.cambridge.org/ebook.jsf?bid=CBO9781139168069
Cambridge Books Online © Cambridge University Press, 2013
•c Contents
3.2.2 Comparators 85
3.2.3 Precision rectifiers 90
3.2.4 Logarithmic amplifiers 96
3.2.5 Analogue computation 101
3.2.6 Active filters 107
First-order circuits 108
Infinite gain multiple feedback (IGMF)
second-order circuits 112
Switched-capacitor filters 123
3.2.7 Pulse and waveform generators 129
Astable multivibrators 129
Monostable or one shot multivibrators 133
Triangular wave generators 135
3.2.8 Inverse function generators 137
Divider 138
Square root circuit 139
Root mean square circuit 140
141
144
149
149
149
151
157
160
164
167
168
169
169
170
170
172
173
174
176
177
4.
4.
4.
4
.1
2
.3
4.4
4.
5
5.1
5.1
5.1
5
5.2
5.2
5
5
.1
.1
.2
.3
.2
.1
.2
Summary
Problems
Oscillators
Objectives
Criteria for oscillation
LC oscillator
RC phase-shift oscillator
Wien-bridge oscillator
Crystal oscillator
Summary
Problems
Phase-locked loops
Objectives
Components of phase-locked loops
Phase detector
Low-pass filter
Voltage controlled oscillator
Principles of operation
Lock range
Acquisition range
5.2.3
5.3
6
6.1
6.1.1
6.1.2
6.1.3
6.2
6.2.1
6.3
6.4
6.5
Contents
'No-lock' conditions and remedies
Applications
Summary
Problems
Modulation in communication systems
Objectives
Amplitude modulation
Modulation circuits
Demodulation circuits
Frequency division multiplexing
Frequency modulation
Modulation and demodulation circuits
Pulse modulation
Pulse coded modulation
Time division multiplexing
XI
180
183
188
189
192
192
192
195
197
198
199
201
202
205
205
Summary 206
Problems 208
210
210
211
212
215
221
221
223
225
230
233
237
241
242
251
257
260
262
7
7.1
7.1.1
7.1.2
7.2
7.2.1
7.2.2
7.2.3
7.2.4
7.3
7.4
7.5
7.6
7.7
7.8
Data acquisition and distribution
Objectives
Digital-to-analogue (D-to-A) converter
Weighted resistor D-to-A converter
R-2R ladder D-to-A converter
Analogue-to-digital (A-to-D) converter
Parallel A-to-D converter
Servo A-to-D converter
Successive approximation A-to-D converter
Dual slope A-to-D converter
Errors in D-to-A and A-to-D converters
Multiplexers
Demultiplexers
Errors in multiplexers
Sample-and-hold circuits
System error analysis
Summary
Problems
xii Contents
8 Computer aided circuit design 266
Objectives 266
8.1 Computer aided design models 266
8.1.1 Ebers-Moll models of bipolar transistors 267
Development of the model 270
8.1.2 Models for field effect transistors 285
8.1.3 Macromodels 287
8.2 Analysis of circuits 296
8.2.1 D.C. analysis 296
8.2.2 A.C. small signal analysis 304
8.2.3 Transient analysis 305
8.3 Programs 306
Summary 317
Problems 318
Appendices
A Typical /i-parameter values for a transistor 319
B HI 506 16-channel CMOS multiplexer 320
C /iA 741 frequency-compensated operational amplifier 322
D LM118/LM218/LM318 operational amplifiers 330
E Polynomials for low-pass filters 335
F Standard design table for low-pass filters 338
G MFlO-type switched-capacitor filters 339
Glossary of symbols 345
Answers to problems 349
References 353
Index 357
Downloaded
发表于 2013-2-6 18:02:24 | 显示全部楼层
关注中~~~
发表于 2013-2-8 09:28:30 | 显示全部楼层
回复 2# wind2000sp3
Analogue Electronic Circuits and Systems-Basak-1991.pdf (8.14 MB , 下载次数: 158 )
发表于 2013-2-8 09:45:40 | 显示全部楼层
回复 3# chlliu
    啊,感谢感谢~~~
发表于 2013-2-21 15:38:08 | 显示全部楼层
好书,赞chlliu
发表于 2013-5-22 15:12:45 | 显示全部楼层
好书,谢谢各位
发表于 2013-5-23 06:59:52 | 显示全部楼层
Thanks for sharing
发表于 2013-5-23 08:45:18 | 显示全部楼层
Thanks for sharing
发表于 2013-5-24 09:44:59 | 显示全部楼层
回复 3# chlliu
好様的
Thanks for sharing!
发表于 2014-1-3 14:14:26 | 显示全部楼层
dinging
GMT+8, 2025-9-17 07:30 , Processed in 0.022398 second(s), 7 queries , Gzip On, Redis On.
