查看: 2294|回复: 1
[招聘] Cadence is looking for IC design, design services Engineer
发表于 2013-2-4 15:39:26 | 显示全部楼层 |阅读模式
Cadenceis looking for IC design, design services Engineer
Ifyou have interest, PLS send your CV to zhangyl@cadence.com
SOC-R Physical Design Team
Positionead Physical Design Engineer
Position Description:
-Performphysical design implementation, including synthesis, floor planning, power griddesign, place and route, clock tree synthesis, timing closure, power/signalintegrity signoff, physical verification (DRC/LVS/Antenna), EM/IR signoff, DFMClosure, and physical design project management.
-Thecandidate will have the opportunity to work on many varieties of challengingdesigns, i.e. low power and high speed design. The responsibility includesparticipating in or leading next generation physical design, methodology andflow development.
Position Requirements:
1.BSdegree with 10+ years of applicable experience, MS degree with 7+ years ofapplicable experience in electrical engineering, microelectronics.
2.Experiencedwith ASIC design flow, hierarchical physical design strategies, methodologiesand understand deep sub-micron technology issues.
3.Solidknowledge on LP Design, DFT, static timing analysis, EM/IR-Drop/crosstalkanalysis, formal verification, physical verification, DFM.
4.Successfultrack records of taping out complex, 65/40/28 nm SOC chips.
5.Automationand programming-minded, solid coding experience in Makefile/Tcl/Tk/Perl.
6.Self-motivated, able to work independently or as a team player, excellentverbal and written communication skills in English.
SOC-R Design Services Team
Positionead Implementation Services Engineer
1.Thecandidates should be senior in a way that they are not only technical excellentbut also mature & able to communicate with customers, following teammembers.
2.Thisengineer should have excellent design experiences in the digital implementationdomain including Floorplan, P&R, STA, Physical verification, DFM.
3.Theengineer must have a solid background in circuits, electronics & physics& should be very willing to learn new stuff.
Key Accountabilities:
1.Abilityto handle large sized design implementation tasks & architectural tasksalone. 2.Ability to assess Customer's Design environment, to understand hisapplication needs & to build new Design environment based on specifications& available Cadence tool technology.
3.Abilityto acquire a basic understanding of the (services) business environment ofCadence within 1 month.
4.Workingon multi person projects of varying complexity, working especially in amulti-site/multi-cultural project. The latter requires good communicationskills in English. 5.Feeling responsible for technical delivery as well asbusiness development & opportunity creation. Behavioral competencies:Teamwork; Customer focus; 6.Accountability; Communication; Coaching &feedback; Employee development; Leadership.
2.Essentialthat the individual demonstrates strong communication, verbal and written, andproject management skills.
3.Requiresgood communication skills in English.
发表于 2013-2-4 21:33:01 | 显示全部楼层
canden招聘的职位都要求好高啊,没有初级中级职位吗
GMT+8, 2025-12-29 11:16 , Processed in 0.017358 second(s), 6 queries , Gzip On, Redis On.
