查看: 7203|回复: 2
[招聘] nvidia 上海招聘-ASIC/DFT/physical design/verif
发表于 2012-12-17 16:14:06 | 显示全部楼层 |阅读模式
Display
Senior ASICDesign Engineer
Responsibilities:
TheASIC design engineer is expected to co-work with architect to definearchitecture/micro-architecture, do RTL implementation and set up projectmilestones and drive design & verification progress and track projectstatus.
MinimumRequirement:
-BS/MS in electrical/computer engineering and related.
-At least 4+ year’s experience in ASIC design/verification.
-Strong design/implementation skills in Verilog. Solid understanding intiming/power optimization skills of digital design.
-Familiar with ASIC design flow such as micro-arch spec definition and testplandocumentation and code coverage and function coverage strategy.
-Strong sense of design timing and area and clock skew issue.
-Strong Perl/Csh scripting skills.
-Fluent English (both written and spoken) and excellent communication skills
-Demonstrated ability to work independently as well as in a multi-disciplinarygroup environment
-Familiar with LCD/LVDS/DisplayPort/HDMI, vertical/horizontal scalar and colorspace is a big plus
ASIC
Design/VerificationEngineer
RESPONSIBILITIES:
-RTL design, verification, synthesis for various low power control logic in GPUchips.
-Develop and maintain verification environment at both full chip & unitlevel
-Code/functional coverage analysis
-Responsible for running both RTL & gate level simulation
-Develop testing and regression methodologies
-Develop/maintain/enhance environment tools/scripts/makefiles
MINIMUMREQUIREMENTS:
-BSEE/MSEE/BSCS/MSCS with 2+~5+ years of experience in ASIC design or verification
-Proficient in Verilog HDL
-Familiar with logic simulators and debug tools (VCS, NCSIM, Verdi and etc.)
-Working knowledge in C/C++, Makefile
-Must have strong programming skills in one or more scripting languages: TCL,Perl, Python
-Knowledge in one of the below areas is a big plus
+ UVM/VMM experience
+ Low powerdesign/verification experience (Multi-Voltage, power gating, UPF/APF and etc.)
+ ARM based SoCverification experience
+ AHB/AXIarchitecture
+ Embedded OS
SOC Verification Engineer(Power)
RESPONSIBILITIES:
-verification for
power managementunit/global power feature of SOC chips.
-Develop and maintain verification environment for cluster level
-Develop feature testplan according to feature description
-BSEE/MSEE/BSCS/MSCS with 3+/5+ years of experience in ASIC design orverification
+ Strong programming skills in one or morescripting languages: TCL, Perl, Python
+ Low power design/verificationexperience (Multi-Voltage, power gating, UPF/APF and etc.)
Sr. ASIC VerificationEngineer (Clock)
Job Description/Qualifications:
RESPONSIBILITIES:
- ASIC Verification for the most complex GPU clock designat both unit level and chip level.
- Debug and fix SOC level issues
- Maintain/Develop the working environment
- Working closely with various unit teams to solve clockissues.
- Support backend team’s work as the bridge betweenfrontend and backend
- Experience in both unit level and chip level verification.
- Good at debugging and problem solving.
- Experience in verification methodology development.
- Programming skills in C and PERL.
- Familiar with clock logic is preferred, such as PLL,clock dividers, trimmers, clock switches, etc.
- Good communication skills, creative, and proactive.
- The ideal candidate will be familiar with all aspectsof the frontend ASIC design flow including RTL design, verification, synthesis,and timing analysis
- BS in Electronic Engineering, MS preferred.
DFT enginner
Responsibilities:
Responsible for DFT implementation including test modecontrollers, Memory BIST/Repair and JTAG based on DFT plan.
Responsible for scan insertion, ATPG and post silicon validation.
Responsible for DFT logic and pattern verification.
Responsible for ATE chip bringup and failure analysis.
Minimum Requirement:
BSEE required, MSEE preferred.
2+ years of experience in DFT/design field
Strong logic Design and verification background withexperience in STA.
Must possess a strong knowledge of DFT including scan, ATPG, Test Compression,JTAG and BIST.
Programming in Perl, tcl and C/C++ is a plus
Good Englisth communication skills
Self-motivated and good team player
GPU ASICPhysical Design engineer
As a senior member of our ASIC-PD team, you'll be working on streamlining thechip infrastructure process across product designs, focusing on full chiplayout planning (partitioning, planning clock distribution and other structure,methodology), partition/full chip timing closure (primetime scripts, othertools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
-Chip integration and netlist generation
-Synthesis,Formal verification, netlist quality check
-Work in conjunction with Place and Route Engineers to achieve timing closurefor both partition level and full chip level
- Develop and enhance entire timing flow from frontend (pre-layout) to backend(post-layout) at both chip and block level.
- Develop custom timing scripts using tcl/primetime for clock skew analysis,special circuits such as clock dividers, core logic <-> IO macrosinterfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
- Develop flow to physically partition and floorplan the entire chip.
- Develop scripts for performing ECO's.
MINIMUM REQUIREMENTS:
- BS or MS in Electrical Engineering or Computer Science
- Above 3 years of relevant ASIC experience ideally with a focus in the chipintegration /synthesis/formal and timing closure
- Excellentscripts skills
- Excellentwritten and verbal communication skills in English
- Ability tomultiplex many issues, set priorities, and work in a team environment
- Keep up todate with leading edge technologies
nvidia内部员工referral
lgao@nvidia.com
欢迎邮件咨询
发表于 2012-12-17 16:21:07 | 显示全部楼层
怎么都是要工作经验的啊,有没有要应届生的啊,,,我在某IC公司实习一年算不算工作经验啊,求内推。
发表于 2012-12-18 16:59:57 | 显示全部楼层
同2楼情况的要不要阿
GMT+8, 2025-12-23 01:01 , Processed in 0.033992 second(s), 9 queries , Gzip On, Redis On.
