Features
· High Common Mode Rejection (CMR): 15 kV/μs at V(CM) = 1000 V
· 5% Gain Tolerance
· 0.1% Nonlinearity
· Low Offset Voltage and Offset Temperature Coefficient
· 100 kHz Bandwidth
· Performance Specified Over -40°C to 85°C Temperature Range
· Recognized Under UL 1577 and CSA Approved for Dielectric Withstand Proof Test Voltage of 2500 Vac, 1 Minute
· Standard 8-Pin DIP Package
Applications
· Motor Phase and Rail Current Sensing
· Inverter Current Sensing
· Switched Mode Power Supply Signal Isolation
· General Purpose Current Sensing and Monitoring
· General Purpose Analog Signal Isolation
本资料由www.xpjm.net整理提供。 |
