查看: 20276|回复: 15
bash:icfb: command not found
发表于 2012-11-1 15:47:23 | 显示全部楼层 |阅读模式
.bashrc的配置如下
# .bashrc
# User specific aliases and functions
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
CDSDIR=/eda
CDS_ROOT=/eda
CDS_INST_DIR=/eda
CDS_INSTALL_DIR=/eda/tools/dfII/
export CDS_LIC_FILE=$CDS_ROOT/share/license/license.dat
export PATH=$CDS_ROOT/tools/binCDS_ROOT/tools/dfII/binCDS_INSTALL_DIR/binCDS_ROOT/tools/spectre/bin:$PATH
export CDS_Netlisting_Node Analog
export LD_ASSUME_KERNEL=2.4.0
安装入境也没错
为什么还是icfb command not found?
高手请指点
 楼主| 发表于 2012-11-1 15:50:13 | 显示全部楼层
IC5141的.bashrc配置
 楼主| 发表于 2012-11-1 15:51:31 | 显示全部楼层
我在安装软件的目录下用绝对路径起的时候也提示:
unable to find the cadence software in your $PATH
please fix this and try again
 楼主| 发表于 2012-11-1 15:52:29 | 显示全部楼层
请教高手此情况如何对.bashrc进行修改配置?
谢谢
发表于 2012-11-1 16:03:12 | 显示全部楼层
reboot after setting up .bashrc
 楼主| 发表于 2012-11-1 16:16:26 | 显示全部楼层
回复 5# just_newbie
    也尝试过了~
还是一样~~
期待高手赶紧支招~急
发表于 2012-11-1 19:21:16 | 显示全部楼层
CDSDIR=/eda
CDS_ROOT=/eda
CDS_INST_DIR=/eda
这些也要export吧
发表于 2012-11-1 20:39:28 | 显示全部楼层
export CDSDIR=/eda
export CDS_ROOT=/eda
export CDS_INST_DIR=/eda
export CDS_INSTALL_DIR=/eda/tools/dfII/
export CDS_Netlisting_Mode=Analog
這一行不必附加 !!
提供參考 !!
发表于 2014-3-12 09:58:28 | 显示全部楼层
zhegeshishenme
发表于 2014-6-30 10:16:29 | 显示全部楼层
回复 1# xy945
GMT+8, 2025-12-30 16:18 , Processed in 0.024103 second(s), 6 queries , Gzip On, Redis On.
